Trying to avoid Noise
tegatwork
I'm trying to avoid Noise on this picture, taken from an animation I'm working on.
My Settings :
Directlighting
Max samples : 16000
GI_mode : GI_DIFFUSE
Hot Pixel : 1
Have you got any clue?
Set "hotpixel_removal" to 0 (which is ON).
Use a single polygon emitter.
Increase the total scene lighting and then reduce the exposure.
tegatwork
Hello,
once again I'm facing noise while using blackbody emitter. In this case, I'm using sweep nurbs as emitter...
I really can't find how to avoid the noise on the floor... any clue?
sadece
in my experience dl-diffuse is not so faster than pt when using same amout of diffuse depth. so you can use pt then have gi clamp feature that you can set it to around 1 for less noise. keep in mind your scene will be darker with same intensity.
http://www.sadece.com.tr
i7 990x // 12GB Ram // 2x Titan X + Titan + 780 // Octane for C4D // Win7 x64
Olitech
I'd also try to increase the emitter samples to a higher number...like really high. 10k, 100k, etc.
best,
O
WORKSTATION = Win7x64 / Intel Core i7-5930K [email protected] / 32GB ram / Liquid Cooled 4xTitanX /3dsMax 2014 / Octane Max Plug v2.16a / FARM = Intel i7-2600k 3.70GHz (x2 TitanZ) x 14
Return to “Works In Progress”
