This is the recommended thread for downloading, and posting any questions, suggestions or support queries for OctaneRender for Poser, build 1.17a (TEST RELEASE). This version is compiled against Octane 1.17, so see the requirements for that build regarding compatibility with your video card.
This version runs on Poser9/PoserPro2012 and Poser10/PoserPro2014, on Windows XP, Vista, 7 and 8.
- Operating System (ie. Win XP, Vista, 7, 8)
- 32 or 64 bit
- Amount of RAM
- Nvidia driver version
- Poser version (Poser -> Help -> About Poser) - list the build number (eg. 9.0.3.23027)
- OctaneRender for Plugin version (ie. X.XXa)
- Also have ready a copy of the octaneplugin.log and cuda.log file from your Poser temp direction (Poser -> Edit -> General Preferences -> Misc tab to find the temp directory)
Change Log from release 1.16a
- Compiled against Octane 1.17
- Added material picking (enable in the Viewport buttons and then click on the Viewport to pick the material)
- Fixed issue with filenames/folder names with special characters in the image, alphaimage and floatimage file selection dialog
- Fixed issue with foldernames with '&' characters corrupting the config.xml file
- If you select a parented or shadow camera whilst rendering, the viewport will continue rendering the previous window (whereas previously it would close the Viewport). You cannot open the viewport whilst viewing a shadow or parented camera though.
This version does not address the bump map power being set to default when pasting keeping original texturemaps - but I will look at it very shortly.
Known Issues
None
If you have questions....
- Read the latest up-to-date on-line manual
- Read the PDF manual (pdf manual is installed into C:\Program Files\Smith Micro\[poser version]\Documentation)
- Read the FAQ
- Watch the Features Video
- Read the Features Blog Posting
- Watch the Introductory Tutorial
- Check the Facebook Page
- Post your question on this forum thread
Limitations
Refer to the on-line manual
Download the plugin HERE
OctaneRender® for Poser beta WIN - build 1.17a [STABLE]
When right clicking in the material list [Geometrygroup] and pick "Export all material for this figure/prop" I get this error:
Strange as I use PP2014
Traceback (most recent call last):
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\SetupForm.py", line 1672, in MenuSelectionCb
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\MaterialManager.py", line 1326, in MenuCommand_ExportMaterialCollection
KeyError: 'scene'Win 11 Pro | i5 12600K | 32GB ram | 2x GTX 1080Ti + 3080Ti - studio driver 581.57| Modo/Blender/ZBrush/Daz/Poser
Hi Zay - you should not be able to export an entire scene - I will disable that menu option for the "scene" tree item.When right clicking in the material list [Geometrygroup] and pick "Export all material for this figure/prop" I get this error:
Crapface_off wrote:Hi Zay - you should not be able to export an entire scene - I will disable that menu option for the "scene" tree item.
Still the naming problem of the figures and props holding this off?
Poser is really not designed for integration and merging of scenes. I believe some of the figure/prop renaming issues have been resolved with Poser 2014, and I will investigate to see what is possible.Still the naming problem of the figures and props holding this off?
Have you tried saving the Octane materials back to the Poser Materials of the scene that you will be importing?
Tiny update has been uploaded - download from the link at the top of this thread.
1.17a2
- Fixed issue where rightclicking the "scene" node would give options to export materials.
- Fixed issue where paste/import RETAINING texturemaps was not retaining the "invert" pin value
1.17a2
Yep, and I get this:face_off wrote:Have you tried saving the Octane materials back to the Poser Materials of the scene that you will be importing?
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\SetupForm.py", line 1695, in MenuSelectionCb
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\MaterialManager.py", line 773, in MenuCommand_SaveAllMaterialsToPoserFigure
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\MaterialManager.py", line 768, in SaveOctaneMaterialToPoserMaterial
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\Node.py", line 2113, in SavePinInfoToPoserMaterial
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\Node.py", line 2105, in SavePinInfoToPoserMaterial
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\UiManager.py", line 1835, in displayError
ValueError: Unknown pin type multiplyWin 11 Pro | i5 12600K | 32GB ram | 2x GTX 1080Ti + 3080Ti - studio driver 581.57| Modo/Blender/ZBrush/Daz/Poser
Yes, that has been an issue in 1.16 too.Zay wrote:Yep, and I get this:face_off wrote:Have you tried saving the Octane materials back to the Poser Materials of the scene that you will be importing?
Traceback (most recent call last): File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\SetupForm.py", line 1695, in MenuSelectionCb File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\MaterialManager.py", line 773, in MenuCommand_SaveAllMaterialsToPoserFigure File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\MaterialManager.py", line 768, in SaveOctaneMaterialToPoserMaterial File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\Node.py", line 2113, in SavePinInfoToPoserMaterial File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\Node.py", line 2105, in SavePinInfoToPoserMaterial File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\UiManager.py", line 1835, in displayError ValueError: Unknown pin type multiply
Wanted to report that yesterday, but then - forgot...
Win11/64Bit | GTX 4090 24GB | NVidia Driver 546.29 | Octane 4.05 | DAZ Studio 4.21
You guys are right - it was not able to save a couple of node types to the Poser material. I have refreshed the installer to hopefully resolve this.Yes, that has been an issue in 1.16 too.
1.17a3
- Fixed issue where certain nodes types were not saving to the Poser material
I have refreshed the installer linked at the top of this thread to fix the following issue:
1.17a4
- Rectify python exception when selecting GI Mode
1.17a4
