OctaneRender® for 3ds max® v1.13[Test]
tonycho
Hi Karba, still on vacation? :) if yes enjoy yourself :D
just want to know. when the 1.15 for max ready?
need the new bump map for my project ;)
thanks
http://www.antoni3D.com
Win 7 64 |GTX 680 4 Gb (Display) | 3 x GTX690 4Gb | Intel i5 |Corsair 16GB
temp-64GTX
Win7 x64, [email protected], 32Gb DDR3 1600, 2xGTX580 3Gb, Corsair 64Gb SSD, ViewSonic 2560x1440
gabrielefx
where is the bug?
temp-64GTX
gabrielefx wrote:where is the bug?
Black dot on the glass. Watch in 720p.
tonycho
Bug in 1.13
when make oval shape (maybe not only ovale)
the edge appear in rendering
gabrielefx
tonycho wrote:Bug in 1.13
you tried with a shell modifier?
what's your rayipsilon value?
tonycho
using shell and not using shell same result
the ray epsilon is 0, hmm I try to increase the lines is reduce but I still can see in some place
what do you think gabriele?
lixai
I have a few unnatural behaviors to report:
- When you switch to manual focus (focus picker) in Render Viewport, after switch off, camera doesn't automatically switch to autofocus (it just stays focused on the last distance I chose)
- When you plug a texture to Image texture in "filename", if you choose to replace Image Texture with (for example) FloatImage Texture, and choose to "keep old map as a sub-map", map gets plugged in the power slot
- Sun position can not be animated ? I can not set a key on the sun.
I'll post more when I find any.
Core i7 860, ZOTAC GTX 580 - 3GB, 2 x GTX TITAN, 32Gb RAM
gabrielefx
tonycho wrote:using shell and not using shell same result
afaik rayepsilon can't be zero...
Btw...I would like to know if Octane for Max will be updated.
I see on the forum many updates for all the other softwares...
The nightly build would nice from were we can have access to the latest development day by day.
Who are the beta testers here? Are we?
tonycho
hahaha yes, change the rayepsilon 0.001 and all done :D
Return to “Autodesk 3Ds Max”
