Testing Beta 0.49/0.50 ( Old version)
indexofrefraction
ok.. i saw this before.. but how do i load a shader then?
do i need to restart first?
i m trying to load a layershader with a color and a circular gradient into emission
(btw see the added comments in the post above)
Mac Pro (2012) 2x6 Core | 24GB | 1 x Geforce GTX580/3GB
indexofrefraction wrote:ok.. i saw this before.. but how do i load a shader then?
no need restart, but not every shader can works. I'm not sure about layer shaders
milanm
Hi everyone it's my first post here.
First of all great work Ahmet!
I was expecting 0.1 or something but we got 0.5 so i'm lovin' it.
I have been playing with Win version and showing my renders at work where we use Osx. In a few cases Octane was around 10 times faster vs. Physical/QMC so they are definitely interested in getting it.
I get a migraine when i have to render anything on a CPU now :-)
My observations so far:
Geometry update feature is not working on a cloner when 'render instances' is enabled.
It updates either only one of the clones or all except one. When rendering final animation everything is fine.
Same thing with the node editor (NV button) here. Once open it can't be closed.
(You can minimize it and continue working but it's there)
'Convert Materials To Octane' crashes c4d when applied to multiple materials that are already assigned to objects.
I also tried gradient and noise shaders in a layer and overlay modes and they worked fine here with shaders option enabled.
Milan
Colorist / VFX artist / Motion Designer
macOS - Windows 7 - Cinema 4D R19.068 - GTX1070TI - GTX780
Welcome milanm,
nice to hear that you like it and speed. So imagine that with multiple gpus how can be fast.
Geometry update option has not tested soo much for instances, in future this option will be improved and optimised.
Node editor is will be disabled temporary. And new gui will come for materials.
Convert Materials To Octane: added to check list, actually support multiple convertions but may be there a problem with a node
ashurao
hi oaktar,
First of all, thank you for all the work done.
secondly, it does not work. :cry:
He asks me my username and password, but can not get the info panel in the account because it is empty. No input field.
Thanks for your help.
Ashurao
EDIT:
Oops ... I found the right panel. Lets go.
Mac Pro 2010 6 cores 3,33 - Mac OS 10.11.6 - 16Go - GTX 780 3Go and GT 640 4Go - Archicad 19 - Cinema 4D R17 Visualise - Octane Render V3
cbmotion
@ aoktar
"this is for mac or windows?"
it is mac osx
i thought this is a mac theme forum here
mac pro 12core quadro 4000
badmilk69
Aoktar, i cant render a object emitter animation, is a bunch of flying diamonds, octane just sit on first frame and do nothing, i can render stills but no animation, not using instances at all, had to bake emitter using nitrobake.
Win version
Update1: animation stopped @ frame 31, had to restart render animation from frame 31 to 120.
i7 2600, 16 GB RAM, 2x Evga 670 SC 4gb, dual boot win7/osxML, 2 SSDs, 3 HDs.
badmilk69 wrote:Aoktar, i cant render a object emitter animation, is a bunch of flying diamonds, octane just sit on first frame and do nothing, i can render stills but no animation, not using instances at all, had to bake emitter using nitrobake.
Win version
need to check your scene to say anything
badmilk69
Win version
Fine, cause your plugin refuse to render now.
PLANOA.zip
(506.27 KiB) Downloaded 213 times
badmilk69 wrote:
Win version
did you check Layer Render settings? It's off
