cannot render any animations with daz studio
Moderator: BK
synapsemedia
I am experiencing a variety of bugs. most of the time geometry will not load into octane viewport. when it does and I try to render out an animation it gets stuck on a frame and does not advance to the next frame. if I try to load an existing daz project file the octane render crashes preventing daz from fully opening and the list goes on.
when will the next version be out?
cheers
angus
p.s. I am still very excited about this plugin and daz studio.
SimonJM
The animation issue is known and is being addressed.
As regards the crash issue it sounds like you might be exceeding the memory of your graphics card, that can have a similar effect, requiring oyu to shut Daz Studio and wait a short-while until 'things clear' (a minute or two should be ok) and the Daz Syudio shoudl then have no more problems with loading scenes.
synapsemedia
ok thanks for the info
jimgale
I am having the same issue... I have the latest plugin (2158 [6,385,664 bytes]). Freezes on my 4th frame (no matter which one I start at).
This is with DAZ 4.6 General Release.
(Previously, I was using the original install - which finished renders, but on loading my scenes, would bomb in octane.dll many times).
I'm absolutely stuck/prevented from continuning.
Any ideas?
orion_uk
http://www.Neil-Isted.com
Intel i7 870/2.93 GHz
RAM 16GB
1x Titan (6GB)
2x GTX 660Ti 2GB
Win10 Pro 64-bit
Carrara 8.5 Pro
Carrara - OR4C
OctaneRender™ for Blender
Ds pro
OR Standalone V4
Poser Plugin
jimgale
Well... that update just solved it right there. Thank you (and t_3!)
Return to “DAZ Studio”
