Instance geometry material maya 2013
aleg_m
Hello all! I am using particles with instance geometry in maya 2013, but when I change the material settings of source geometry, material particles does not change. What i doing wrong? Thank you very much!
Win 7 x64 | 2 x Nvidia GTX580 1.5 Gb | p6x58 premium | i7-960 | 16GB extreme | Octane Benchmark 7.15
JimStar
aleg_m wrote:Hello all! I am using particles with instance geometry in maya 2013, but when I change the material settings of source geometry, material particles does not change. What i doing wrong? Thank you very much!
Can you please explain it a little more, are you speaking about the IPR mode?
aleg_m
there is no difference ipr or batch render. i do not know how to assign осtаne material to instant geometry particles. is it possible?
aleg_m
dear octane! please fix this bug!
JimStar
Dear aleg_m.
JimStar wrote:Can you please explain it a little more?
Please, I need detailed "step by step" description of what you do and what you get, to try to reproduce this.
I can not answer on your question
aleg_m wrote:What i doing wrong?
if I don't know what you are doing...
aleg_m
i have poly object with octane diffuse material in my scene. i create particles emitter and make particles instance with this poly object. start ipr render and trying to tune octane diffuse material which assigned to poly object (particles). changing parameters of material nothing happens in ipr render window.
JimStar
aleg_m wrote:i have poly object with octane diffuse material in my scene. i create particles emitter and make particles instance with this poly object. start ipr render and trying to tune octane diffuse material which assigned to poly object (particles). changing parameters of material nothing happens in ipr render window.
I can't reproduce it on my machine.
Perhaps you can share the scene where you are not able to do it?..
