OctaneRender® for 3ds max® v1.13[Test]
retmia
I just wanted to point out that I've lost a lot of stability since 1.12 and 1.13, 1.11c was fine even though it burned one of my 590GTX.
I try to render in low priority with my two 590GTX, but still it's crashing more or less every 20 frames rendered ... for a 40s render per frame in direct lighting ... with the rebooting time for every crash, it makes it less practical to use !
I hope it will get more stable on the next release.
Thanks for the hard work !
retmia.net
retmia.blogspot.com
i7 3930k - 2x ASUS GTX590 - 16GB DDR 3 - Corsair AX1200
BKEicholtz
Re: OctaneRender® for 3ds max® v1.13[Test]
Hello! I will add that I was unable to use the test releases with the latest iToo Forest Pack. I was getting constant crashes. I had to go back to the non test release. I wanted to share this, and I echo other users... Thanks for the hard work, and great product!
ASRock Extreme11 | i7 3970x 5.0 Ghz | 32gb RAM | (4) EVGA SC Titans
bicket
Hi karba
The difference between octane viewport and 3dsmax frame buffer still exists.
Can you fix it please, I can't render my animation for now and I'm pretty disappointed with octane evolution ;)
DL diffuse 2 / 1000 samples / HDR environment
[edit]
It appears when I use a glossy mat with a mix texture in the diffuse slot.
When using 3dsmax frame buffer, the float texture used as amount in the mix texture of the diffuse slot is not (or badly) taken in account.
PortFolio
4 x TITAN - Win 7 64 - Octane Rocks
gabrielefx
I already reported this issue.
@Karba
please don't abandon us!
Karba
gabrielefx wrote:I already reported this issue.
@Karba
Hi
Unfortunatelly I have a vacation at the moment. I will fix it right after I will come back to work.
bicket
Enjoy your vacation, there's some hard work here ;)
PortFolio
mbetke
BUG:
If you use alphachannel on a Specular glass material the background draws behind it and alpha is white at this spot.
It should be not 100% opaque but a bit transparent.
PURE3D Visualisierungen
kevinshane
hi Karba, any news of proxy cloud format?? it's really important function ~~ still waiting ^^
MSI GT70 laptop i7-3610QM+32G+GTX680M 4G
Octane Arch/Interior Viz Tutorials
http://www.kshane.com
mykola1985
darkline wrote:
solomon wrote:
Do you mind, sharing a screen grab of the turn your hair to geometry at render time? I have tried it but it's not rendering the hairs
Hi Solomon,
Did you read the following post where I outlined the steps under which it would work? (I only found this out when I went back to render the next day).
The 'geometry' setting is in Max's 'Environment and Effects' window (push 8 on keyboard to bring up environment/effects tabs). Click the hair and fur effect and change the dropdown there to geometry.
I did that in max 2014 and with octane v1.13 the hair and fur is not working..... :( how is that possible????
i7 3770K, 12GB RAM, ASUS STRIX GTX 780 - 6GB OC Edition + ASUS GTX 780 Ti - 3GB, win 7 ultimate 64bit
mykola1985
is there anybody else having problems with rendering hair and fur in this version?
Return to “Autodesk 3Ds Max”
