Preset materials for Octane/Poser
Lightray
Is there any chance of having a preset of materials, like metals, wood, concrete, etc. that will be available in the materials window?
This would help speed things along a great deal.
Hi Lightray
You can do this easily already. Setup a metal material in the plugin Materials Tab, then rightclick the material and select "Export Material", name it "Metal Preset". Do the same for wood, concrete etc. Then when you next need to use one of these, rightclick the material and select "Import Material" and select the wood, metal, concrete, etc preset.
mitzzy50
Excuse me you both for the intrusion to the post. I wanted to know a quick question about the materials. Is it possible to change more than one material at the same time in the same object from poser inside the plug-in? Example: a material from livedb. I tried holding on Ctrl, Alt and/or Shift and I didn't have luck
Multiple selection is not directly supported, but something I've looked into. At the moment, you can use the "Paste to all skin materials", and "Paste to all props named ???", which allow you to make a change once and then propagate that change to many materials quickly. I would love to add the facility to select say 3 materials, then change the bump from 0.1 to 0.2 on one of the materials and it changed the other 2 too - but there are some technical challenges in doing this. But it's definitely something that I'll keep on the plugin roadmap.
RGUS
Yeah.. now that would be good... like change everything from glossy to diffuse...
RAM: 64GB
OCTANE PLUGIN VERSION: 2022.1..1.302 Prime
DAZ STUDIO VERSION: 4.21.0.5 Pro Edition (64 bit)
RGUS
Oh yeah... sorry... and while ya at it... can you automatically update the V4 texture... or any texture really when you do a scene refresh to the new textures rather than having to go into Materials ans reload between changes of textures. I'll bugger off now...
RAM: 64GB
gazukull
I am with RGUS on this one, it would be great to change near everything from glossy to diffuse at one time. Is there a way to make diffuse the default for things pushed to octane that isnt spec?
Win 8.1 X64 / 6x780GTX / AMD FX-8320 / 32GB RAM
ch0pper
yep me two! :D
W7 64 bit |I7-3970X | GTX 780 X2(6GB) GTX 780TI X2 | 64 GB DDR3 RAM
Real Skin & real hair for Poser / DAZ Studio OctaneRender/iray - coming soon
wimvdb
RGUS wrote:Oh yeah... sorry... and while ya at it... can you automatically update the V4 texture... or any texture really when you do a scene refresh to the new textures rather than having to go into Materials ans reload between changes of textures. I'll bugger off now...
I am against this - if at all, it should be optional.
I would not like to destroy my octane material setup because I changed a texture in the poser material room
Unless you mean something else...
Configuration: Windows 11 Pro, I9 12900K, 128GB, RTX 3090, P12 b1029
KleanZlate
I agree, it would have to be an option. It's fairly easy to right click the figure in the materials list and re-import it if you've changed the textures in Poser.
Windows 8 64bit, Intel Xeon 3.4 GHz x2, 10GB RAM, GTX 660 Ti 2GB, Poser Pro 2012 SR 3.1
Return to “Poser”
