Testing Beta 0.42 (OBSOLETE VERSION)
colinoctanerender
I just want to mention that when I try to download some of the materials from the database C4D gives me an error and it force closes the program...I'm sure you're aware of this, just wanted to make sure. Thanks for the great work you've done so far!
colinoctanerender wrote:I just want to mention that when I try to download some of the materials from the database C4D gives me an error and it force closes the program...I'm sure you're aware of this, just wanted to make sure. Thanks for the great work you've done so far!
thanks. And yes, but if you give me names i can fix it. I cannot check every materials
Geometry Update test video:
This show while new method is testing. This method provides faster render and much more reliable older one.
We have a ObjectTag to indicate which meshes will be updated. Has several mesh layers. Every mesh layer provide a assigned Octane mesh and only related meshes are updated. Layer 0 is for static meshes, bigger numbers for dynamic meshes
[vimeo]http://www.vimeo.com/65694139[/vimeo]
Druzic
Sweet!! Is it running on Octane 1.14? ( looks like it might be in the test...)
Druzic wrote:Sweet!! Is it running on Octane 1.14? ( looks like it might be in the test...)
yes 1.14 and still testing
pulsegroup
Can I/we ask - what is your setup showing the live/c4d footage above? (in terms of gpu and screen cards)
2xgtx 590, one gpu is for desktop, 3 is for rendering
losklonos
Hello,
I have a problem with Cinema R14. I have installed the last version 0.42 but when I want to create “mix material“ the programs crashes. It also happens when I open a scene which contains “mix material“. It started to happen after the last update of Cinema.
losklonos wrote:Hello,
hi,
we found a problem in there. It causes to occur crashes on someone. If you can wait a little i'll publish newer one but need more test and fixes
mate
Hey Aoktar,
::mate::
SEHSUCHT Berlin - 22x GTX 780
i suppose we took
:mrgreen:
