OctaneRender® for 3ds max® v1.13[Test]
solomon
darkline wrote:When did this get fixed? :-)
Using 3dsmax 2014 you can now use 'hair and fur' with octane. Just check the option to turn your hair to geometry at render time. Previously I had to convert the hair to a mesh from within the plugin - but that meant you couldn't have animated hair/grass, now you can.
I did this super quick cheap test to see if it worked.
Thanks Karba whatever you did, this is very useful
Do you mind, sharing a screen grab of the turn your hair to geometry at render time? I have tried it but it's not rendering the hairs
Solomon W. Jagwe
3D Artist/Animator/Modeler | Independent Film Director
http://www.solomonjagwe.com | http://www.nkozaandnankya.com
truerender
Strange star in post processing after 2000 - 3000 samples
darkline
Hi Solomon,
Did you read the following post where I outlined the steps under which it would work? (I only found this out when I went back to render the next day).
The 'geometry' setting is in Max's 'Environment and Effects' window (push 8 on keyboard to bring up environment/effects tabs). Click the hair and fur effect and change the dropdown there to geometry.
Windows 7 64bit/ Intel 3930K/ ASUS Rampage IV/ GTX980ti x 2/ 64GB system RAM
mbetke
Shouldn't the transparent glossy stuff not fixed??
Just rendered an image and got this:
PURE3D Visualisierungen
Blazer1985
ifl support.... AWESOME!!!!
Thanks again karba
Mobile Workstation: Alienware m17x R4, GTX 675m
Karba
mbetke wrote:Shouldn't the transparent glossy stuff not fixed??
We will have look on it. What kernel do you use?
gabrielefx
please Karba check the issue that I've posted
for me 1.13 is not usable.
mbetke
I used Pathtracing.
gabrielefx
@Karba
could you add lens mm equivalent in the camera parameters?
many clients told me: add this lens. They refer to real lenses and not to fov.
nobody knows that a 24mm corresponds at 73,739792 deg
thank you
bicket
gabrielefx wrote: nobody knows that a 24mm corresponds at 73,739792 deg
Just because it doesn't, or it does only for a 4/3 image ratio
For example, a 1920 x 1080 (16/9) image with a 24mn camera corresponds to 45,483616 deg
That's not so trivial ...
PortFolio
4 x TITAN - Win 7 64 - Octane Rocks
Return to “Autodesk 3Ds Max”
