OcDS UPDATE v1.0.111.2158 - OUTDATED
Moderator: BK
TakashiKurashima
Hmmm, in my environment, OcDS inhibits the D|S scene initialization always.
<OcDS plugin on, restart D|S>
<D|S Start>
Fragment Shader:
Fragment Shader compiled successfully.
Linking Shader:
Fragment info
0(29) : warning C7050: "_rgb" might be used before being initialized
Shader Program successfully linked.
OctaneRender: Plugin started.
< at first, File-New scene >
*** Scene Cleared ***
Error occurred attempting to clear the scene
<OcDS plugin off, restart D|S>
<D|S Start>
Compiling OpenGL Shader...
Fragment Shader:
Linking Shader:
Fragment info
<at first, File-New scene >
GPE does not occur If there are no objects in the scene, only error is reported in the log.
but it causes GPE with just only one "primitive sphere" in the scene.
If I do not load the file, I do not New scene, these errors do not occur, OcDS works smoothly.
I wonder if this is dependent on the some setting of OcDS.
I want you to tell me if there is a way to complete initialize OcDS setting.
t_3
TakashiKurashima wrote:Hmmm, in my environment, OcDS inhibits the D|S scene initialization always.
the only way to tell, if it is the plugin or something else would be to load scene files without the plugin turned on. after the error in the line above did occor, it won't run stable any longer.
TakashiKurashima wrote:If I do not load the file, I do not New scene, these errors do not occur, OcDS works smoothly.
yes, in this case DS doesn't do a scene clear - so this error does not occur (whatever is causing it); in addition the plugin does not need to clear the project and will just work.
TakashiKurashima wrote:I wonder if this is dependent on the some setting of OcDS.
not any i'm aware of. there were already other troubles, but not a scene clear error, which causes subsequent database errors. sorry to say, but this seems to be very specific to your setup ;)
TakashiKurashima wrote:I want you to tell me if there is a way to complete initialize OcDS setting.
it needs to run when DS calls for it (whenever "new" is selected, or whenever a scene is loaded). as this process is interrupted by an error, the octane data won't get correctly set up, and there is no way to do this later.
to somehow find out what happens, please do load scenes and clear scenes with "new" without the plugin. turn it off from the DS plugins dialog, or just temporarily remove the plugin dll from the plugins directory.
if the error on clear still shows up, it must be something else (of course). if not, i need to provide you a test version which does extensive logging of clear scene process, to see what or where it goes wrong...
„The obvious is that which is never seen until someone expresses it simply ‟
TakashiKurashima
You may tell the possibility of collision between the plug-ins, or other functional.
Well noted.
I try to create a clean DAZ Studio as much as possible, to eliminate the other plug-ins,
If I can find a plug-in that conflict with OcDS, I'll report it.
Regards.
t_3
TakashiKurashima wrote:You may tell the possibility of collision between the plug-ins, or other functional.
Well noted.
Regards.
you don't need to put lots of effort into it! just turn the octane plugin off, try again to load a few scenes, klick "new", if the "error on clear" is gone, you don't need to look any further, as i need to do that from this point on ;)
TakashiKurashima
I think I was able to make minimum error scene probably,
In my environment, loading many times the scene file below, and ACCESS_VIOLATION occurs.
This file has a scene where there is only one sphere primitive.
https://skydrive.live.com/#cid=9E5F8EE5 ... A682%21187
Indeed, the first error occurs in the scene cleanup at dzscene.cpp, next error become a fatal trying to read the duplicate dataset from memory DB.
However, I do not know why the first error does not occur if the OcDS plug-in off.
p.s. Scene cleanup error occurred even when I remove all plugins from the plugins directory other than OcDS.
CASE 1 : OcDS is off , load the scene file many times ..
Linking Shader:
Fragment info
File loaded in 0 min 0.0 sec.
Loaded file: Sphere.duf
Saved image: C:\3D\DAZStudio-SaveFiles\Sample\Sphere.duf.png
CASE 2 : OcDS is on , load the scene file many times ..
File loaded in 0 min 0.1 sec.
WARNING: general\dzscene.cpp(1530): Error in DzScene::clear()
DEBUG: "20:37:56: 0"
DEBUG: "20:37:56: database name: :memory:"
DEBUG: "20:37:56: *********************************** SQL ERROR BEGIN ***********************************"
DEBUG: "20:37:56: No[19]: columns Pointer, Guid are not unique Unable to fetch row"
DEBUG: "20:37:56: driver text: Unable to fetch row"
DEBUG: "20:37:56: databaseText columns Pointer, Guid are not unique"
DEBUG: "20:37:56: query:
INSERT INTO [DzNodes] SELECT * FROM [import].[DzNodes]"
DEBUG: "20:37:56: ************************************ SQL ERROR END ************************************"
DEBUG: "20:37:56: No[19]: columns Pointer, Guid, RootPtr are not unique Unable to fetch row"
DEBUG: "20:37:56: databaseText columns Pointer, Guid, RootPtr are not unique"
INSERT INTO [DzMaterials] SELECT [Pointer], [RootPtr], [ParentPtr], [Label], [Md5], [Guid], [IsProcessed], 0 AS [MatIndex] FROM [import].[DzMaterials]"
DEBUG: "20:37:56: No[19]: column Key is not unique Unable to fetch row"
DEBUG: "20:37:56: databaseText column Key is not unique"
INSERT INTO [Settings] SELECT * FROM [import].[Settings]"
or
Executing startup script...
Started in: C:/Program Files/DAZ 3D/DAZStudio4
DAZ Studio Started
Creating Pixel Buffer
Pixel buffer - Width: 1024 Height: 1024
Fragment Shader:
Linking Shader:
Fragment info
DEBUG: "20:43:09: 0"
DEBUG: "20:43:09: database name: :memory:"
DEBUG: "20:43:09: *********************************** SQL ERROR BEGIN ***********************************"
DEBUG: "20:43:09: No[19]: column Key is not unique Unable to fetch row"
DEBUG: "20:43:09: driver text: Unable to fetch row"
DEBUG: "20:43:09: databaseText column Key is not unique"
DEBUG: "20:43:09: query:
DAZStudio.exe caused ACCESS_VIOLATION in module "C:\Program Files\DAZ 3D\DAZStudio4\plugins\OctaneRender\plordazs.dll" at 0033:00000000108C6DFD, DzMatrix3::operator float * __ptr64()+1830549 byte(s)
t_3
TakashiKurashima wrote:Indeed, the first error occurs in the scene cleanup at dzscene.cpp, next error become a fatal trying to read the duplicate dataset from memory DB.
thanks for giving it a try! the really important things happen during the scene clear. unfortunately DS catches any exception that happens during this process, so it will never crash already at the point where the problem really exists, but of course afterwards things are not set up in valid way, and this causes all the following errors. i'll need to prepare a special debug version, which will need some time. i'll send you a pm as soon as done...
larsmidnatt
i forget where we were having the discussion about the render viewport never loading/starting to render, but I have had it happen many times again. Most of the time hitting the reload button indeed fixes the issue. Sometimes only restarting DS works.
There are a few scenarios that cause it, such as loading a scene that already has octane data. Sometimes it just never loads. Other times it's after you have paused a render, and make a bunch of changes when paused and then unpause. Seems to get stuck.
But since reload does work the majority of times I'm not too worried, but I wanted to give an update.
Win10 x64
i9 10900k 64GB
2080S 8GB
DS 4.15 OcDS Prime ^_^
aalpontes
I know its a little late, but good work, and get well soon. Hope your ear is better alreadyhttp://render.otoy.com/forum/posting.php?mode=reply&f=44&t=30373#
t_3
aalpontes wrote:I know its a little late, but good work, and get well soon. Hope your ear is better alreadyhttp://render.otoy.com/forum/posting.php?mode=reply&f=44&t=30373#
yeah, it's ok already - thanks!
Andrey79
When you are planning next update for OctaneRender DS?
Return to “DAZ Studio”
