OctaneRender® for Poser beta - build 1.11u [OBSOLETE]
Thanks for letting me know Zay. Definitely a Reality bug. Nothing to do with the Octane plugin.
Pandarr
Zay wrote:There seems to be some conflict with the new Reality 3 plugin and the Octane plugin.
D:\Poser Pro 2012sr3.1\Runtime\Python\addons\Reality\__init__.p y:97: RuntimeWarning: tp_compare didn't return -1 or -2 for exception
Paolo thinks it's an issue with the Octane plugin as there's no tp_compare in the Reality 3 plugin. So who's right and how do we fix it ?
A new version of Reality came out today which fixed this... for me anyway.
mlru
OK, there's definitivly some strange in this version.
On several times i have crashes with this version, i never had in the versions before:
Traceback (most recent call last):
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\OctanePlugin.py", line 10431, in ShowOctaneOptionsWindow
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\OctanePlugin.py", line 7483, in Init
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\OctanePlugin.py", line 8805, in refreshScene
File "C:\Program Files\Smith Micro\Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\OctanePlugin.py", line 9774, in copyMeshToOctane
WindowsError: exception: access violation writing 0x0000000000000000
Sadly it's not very good reproducable, but right now I'm having this when I load a saved file and try to bring it to Octane. Sometimes after hiding or adding a prop, it loads into the plugin and works just fine. That's the only workaround I've found so far. As I said, that never happend in the previous versions and is surely not a matter of texture or poly count.
I've added the logfiles, if that helps.
Uwe
octanelog.zip
(4.75 KiB) Downloaded 337 times
Win11/64Bit | GTX 4090 24GB | NVidia Driver 546.29 | Octane 4.05 | DAZ Studio 4.21
Uwe
I have just uploaded a versed version which potentially fixes this issue. Pls re-download 1.11u (this new version will show "1.11u-5" on the Setup screen title). This version also fixes a bug that was being triggered if texturemap files had special characters in them.
Hi
I have just uploaded a revised version which addresses the following:
1.11u-6
Fixed bug where sometimes animation settings would not be saved
Fixed issue where non-numeric characters could be entered into the animation "end frame" text box
Pls re-download from the link in the first msg of this thread.
orion_uk
Thanks V-much indeed :)
http://www.Neil-Isted.com
Intel i7 870/2.93 GHz
RAM 16GB
1x Titan (6GB)
2x GTX 660Ti 2GB
Win10 Pro 64-bit
Carrara 8.5 Pro
Carrara - OR4C
OctaneRender™ for Blender
Ds pro
OR Standalone V4
Poser Plugin
RGUS
face_off wrote:Hi
1.11u-6
Hi Paul...
I just downloaded and unzipped the X64 version to my poser sub-folders, restarted Poser and now no "Octane Render" under the Render pulldown... how to I get it back?
RAM: 64GB
OCTANE PLUGIN VERSION: 2025.6.0.4.09 Prime BETA
DAZ STUDIO VERSION: 4.24 Pro Edition (64 bit)
Sounds like it installed in the wrong folder. Did you delete the previous version? (I normally don't - you can safely install new version over the top of the old ones).
You only need ...
Poser Pro 2012\Runtime\Python\addons\OctaneRender for Poser\__init__.pyc
to get the OctaneRender menu item to show.
RGUS
OK checked the file exists in the correct folder... image attached...
Ran the python script manually from Poser File pulldown menu... and got the second image error message.
If you say re-install Poser, I'm gonna spit the dummy...LOL
Any glues?
path image_002.jpg (12.55 KiB) Viewed 5547 times
RAM: 64GB
RGUS
Oh and BTW paul... after doing all that... still no Render Octane option... though I have been able to get it to work under the 32bit version of Octane... sort of defeats the purpose of an i7 though.
Regards,
Deane
RAM: 64GB
Return to “Poser”
