done or almost done:
- separated oc<>dz focal distance, aperture (f/stop) and dof switch
- additional oc f/stop slider, for those who prefer a real world value
- additional option to manually get the current focal distance from the daz camera
- much better preview in the image menu (pinned to the hovered entry, left or right wherever is space)
- additional current image view on selection ddbox mouseover
- open folder (windows explorer) of the current image
- directly open a map in an image editor of your choice
- reload current map (or multiple maps) from disk ... this was/is not quite as straight forward as i thought
- remove unused maps from the image menu
- unused maps will also be removed on save (so the image menu isn't that cluttered on open)
- "highlighting" of pins about to connect in the nge
- del key captured in the nge and in the octane mats tree = triggers the natural deletions there and leaves scene stuff alone
- animation forward working again
still in the works:
- saving/loading back of environment settings (the reason causing this to fail is however identified)
- there is an issue which "eats up" threads - this leads sooner or later to problems because things stop to work if they can't create new threads - this one needs to be completed before another update can be released.... i'll keep you posted.
