Plugin does not respect negative scaling values
Moderator: BK
larsmidnatt
Sometimes I like to use negative scaling values to mirror environmental objects. The plugin seems to only view scaling in absolute terms, so I can't use this trick easily anymore. I occasionally will scale something -100% in the X axis and voila I have a mirrored object. I have a workaround, I think exporting the mirrored object to obj and importing should get around it, but would prefer not having to do this.
I'd put this as a minor issue.
Win10 x64
i9 10900k 64GB
2080S 8GB
DS 4.15 OcDS Prime ^_^
t_3
larsmidnatt wrote:Sometimes I like to use negative scaling values to mirror environmental objects. The plugin seems to only view scaling in absolute terms, so I can't use this trick easily anymore. I occasionally will scale something -100% in the X axis and voila I have a mirrored object. I have a workaround, I think exporting the mirrored object to obj and importing should get around it, but would prefer not having to do this.
in fact octane does not support negative scale values through placement nodes. since i already partly excluded scaling form the placements, to work around another octane shortcoming (regarding emission intensity), there might be a slight chance that i also find a workaround to allow this, even if octane doesn't.
if you switch to final, you will get the objects mirrored, since there are no placements used. another thing i don't exactly like, but currently i'm short of miracles ;)
„The obvious is that which is never seen until someone expresses it simply ‟
larsmidnatt
interesting to know, i've got workarounds so it's all good. I just thought it was a bug and not a limitation of Octane render(placement nodes), knowing it works in final render mode also helps. Thanks.
Win10 x64
i9 10900k 64GB
2080S 8GB
Return to “DAZ Studio”
