Cleaning up unlinked materials from the Image selection menu
Moderator: BK
linvanchene
edited and removed by user
t_3
short answer: there was a bug in the maps cleanup, which i just noticed shortly after releasing the last update where the merge cleanup was addressed (was something similar).
to keep maps no longer loaded in ds (within a session) is on the other hand intentional, since you may sometimes like to go back to another map you have recently used - which you can then still get from there without browsing the disk.
to be honest, i don't have any idea how to address menu entries, that don't fit on the screen - this is a standard Qt ui-element, so i'd hope the framework takes care of that. but i think it would be a good idea to have a cleanup function directly within this menu (below "browse" for example something called "remove unused maps"), so you can decide yourself when to trash stuff no longer needed...
„The obvious is that which is never seen until someone expresses it simply ‟
t_3
btw, cool guy! i hope a few of you all will allow to use some images for promotion/manual/...
Return to “DAZ Studio”
