how to get Archicad 3D people bitmap in Octane
Graphisoft ArchiCAD (Integrated Plugin developed by Paul Kinnane)
rappet
Does someone has any idea how to get Archicad 3D people bitmap object right in Octane?
I hope the printscreen speaks for it self,
greetz,
4090+3089ti & Quad 1080ti
http://www.tapperworks.com
The shadow on the ground near her feet in the AC viewport it square, so it's likely they are using a Transparency map. If oyu can find that map, plug it into the opacity node of the material in Octane.
Are you sure that is a 3d person? Maybe it is a 2d person? I just checked a 3d person a they rendered fine.
Here are the people...
rappet
face_off wrote:Are you sure that is a 3d person? Maybe it is a 2d person? I just checked a 3d person a they rendered fine.
Yes, it is confusing :roll:
It is a 2d bitmap, but it is in the Archicad library folder "3D people"
I tried to change the material with png's (also mask for transparant),
but to start the scale is totally wrong to start with.
Return to “Graphisoft ArchiCAD”
