PAQUITO wrote:Incredible use of the AO kernel. All the images are great, but the first two are simply perfect. I wish I could produce images as good as those. Congratulations.
Thank you very much Paquito but for my opinion you are able to produce images equal or better than those (and you usually work with complicated scene); I'd like to produce this kind of result with full environment scene and not only with colose-up.....we will see what will come out when the whole scene will be completed
merid888, for the first view (test1_camera_alta) exp:1,17 f-stp:2,8 iso:136 sat:0,79 vignetting:0  camera response: max zoom 800CD
              for the second view (test_camera_vista_bassa) exp:1 f-stp:2,8 iso:100 sat:1 vignetting:0,5 camera response: Agfacolor HDC400PLUS
              for the third view (test_camera1) exp:1,16 f-stp:2,8 iso:129 sat:0,82 vignetting:0  camera response: max zoom 800CD
              for the fourth view (test_camera2) exp:1,17 f-stp:2,8 iso:136 sat:0,79 vignetting:0  camera response: max zoom 800CD
...adjusted the exposure in post + little color correction + light vignetting only to the bottom part of the images
kavorka, thanks for the information (the books were imported from other scenes), could you tell me exactly which are the books?
Cheers, Paolo
intel i7 3820 3.6GHz, 16Gb 1600Hz, windows 7 professional 64bit, gtx 580 3Gb x2, Octane 3dsMax 2.58
