This option is available inside the Image Texture node ... you can load a color image, but if you set the node type to "float image", it is converted to gray scale and uses three less GPU memory than a color image.gordonrobb wrote:But float node doesn't have an input. It is just an output, that outputs a value. It can go into power for example, but can't take an input.
