integrated Octane for Cinema Beta
mauricesteenbergen
One feature I really miss from the standalone (besides LiveDB, but I know you are working on that)
Material Picker!
I don't know if this is possible within C4D, but It would be really awesome if we could just pick a material in the Octane preview window and have that automagicly opened in the attributes window of C4D.
Render: Geforce GTX480 (EVGA) (1.5GB) | OC @ 1.0V / 750Mhz
Display: Geforce 8800GT (NVIDIA) (512MB)
OS: Win 7 x64 | CPU: Quad Intel Xeon 2.66GHz (12GB)
mauricesteenbergen wrote:
aoktar wrote:
if you have integrated plugin it's easy.
you must open multiple Cinema4d.exe with -parallel parameters.
In render setting set output frames to different ranges. Of course you must select Octanerender for render engine.
An start render on each copy of c4d.
Great tip Aoktar, have been searching on how to open multiple C4D instances on one machine.
I found another bug: if you work with the preview window for a while, and you decide to render a full frame with the renderer (shift+r), the preview size has changed after that.
I would like to thank you for your hard work on the plugin, I just bought it and I already love it. I got used to the standalone, but it's so much easier this way. I'm sure you'll get rid of the bugs soon, It's been running pretty good here up until now.
:) welcome and enjoy it.
plugin gives much different possibilities. We did very fast development, because of interest of people. So somethings is not perfect or missing. But most critical features is there. Also some good features on the way.
keep your interest :)
@mauricesteenberge: Hi, material picker will done soon
nehale
aoktar wrote:
nehale wrote:
That's sounds awesome!, can you do a tutorial showing just that?
how excatly do you "open multiple Cinema4d.exe with -parallel parameters." sorry im a noob at this
Nehale
Windows 10 x64 | 2x GTX680 | i7 990X | 24GB
Cinema 4D R17 Studio + 3Ds Max 2017
OctaneRender™ for Cinema 4D 3.01 + OctaneRender® for 3ds max® v3.14
"c:\Programme\MAXON\CINEMA 4D\CINEMA 4D.exe" -parallel
from windows menu
mauricesteenbergen
aoktar wrote:"c:\Programme\MAXON\CINEMA 4D\CINEMA 4D.exe" -parallel
from windows menu
I just created a new desktop shortcut with the -parallel added, and named it C4D Multi
So now you can choose if you start a single instance or multiple. (in case you click too many times).
Screenshot included.
pxlntwrk
hi,
Is octane for c4d support distributed render ?
pxlntwrk.net
pxlntwrk wrote:hi,
It support network and batch rendering for seperate frames
d3d-design
Will there be a network-license?
Or do i have to buy the full-package for every render-node?
pxlntwrk
Ok thanks for reply,
For clarify for me :
net rendering via net render ?
what do you mean by batch rendering?
pxlntwrk.net
pxlntwrk wrote:Ok thanks for reply,
net render and also render queue rendering. So have all possibilites for rendering except distribute one frame on multiple machines.
d3d-design:
currently yes, need seperate copies. But you can ask for that to Otoy
