Just got my license today, and I`m still cranking @ 2am. are there any material collections or test scenes available?
I have converted a few materials, but still, don't come across pretty accurate,
Thanks! Super release!
materials and test scenes
converted materils doesn't work that good..but there are material database =) so You can use hat to browse & learn something. after that You can try to make Your own mats, what is not so difficult =)
as for the test scenes, there are those used for benchmarks & some users share their scenes on forum too =) something from developers are shared too. so take a look & You'll find something out here!
hi, welcome stoiqa. I'm glad to hear thats.stoiqa wrote:Just got my license today, and I`m still cranking @ 2am. are there any material collections or test scenes available?
i have posted before some thread. Some scenes outdated, will updated soon. Also i'll send a update for plugin in this forum soon. Please check again
SAMPLES: http://www.aoktar.com/software/c4dOctan ... scenes.rar
MANUAL: http://www.aoktar.com/software/c4dOctan ... manual.pdf
hi,
thanks
sorry but i cant find it ? inside the pluggin or inside the octane ?glimpse wrote:but there are material database =)
thanks
pxlntwrk.net
pxlntwrk.net
could not find the material database either, but I agree, from production stand point, it would be super to have accurate materials database setup, instead of replacing 200 textures
Octane is only using GPU, is there a way to make it see also the CPU (dual x5690)?
Last night I brought couple of scenes from work, and one scene has over 200 textures, I was getting a memory error from octane. Is this a limitation of my card.
Havent upgraded the card yet, still on the fence of what should I get. Currently have 560ti, suggestions welcome
Hi Stoiqa,
Yes, the entire scene needs to fit into your GPU's VRAM. For a 560ti this would most likely be 1GB.
Also there is a texture count limit:
The current limitation on pre-Kepler GPUs is:
- 64 LDR RGBA textures
- 32 LDR greyscale textures
- 4 HDR RGBA textures
- 4 HDR greyscale textures
The current limitation on Kepler GPUs is:
- 144 LDR RGBA textures
- 68 LDR greyscale textures
- 10 HDR RGBA textures
- 10 HDR greyscale textures
So you may need a GPU with more VRAM and a Kepler with some tweaking of the textures to render this scene. Otherwise you would need to reduce the polygon count, texture size and count to fit this into your GPU.
Currently you can get 4GB 660ti/670/680's and the Titan has 6GB
Chris.
Chris.
- [email protected]
Hey ho
So how can I get to the material database from in cinema 4d?
Thanks a Lot!
Your's sincerely
Tim
Thanks a Lot!
Your's sincerely
Tim
Hi,[email protected] wrote:Hey ho
Thanks a Lot!
Your's sincerely
Tim
liveDB acces in development. Next update will have that. In a 1-2 weeks.
good to hear that!!
pxlntwrk.net
pxlntwrk.net
