Great and really fast work guys.
This made my day!
Keep it up!
EDIT:
Bought it
This is like Christmas!
Cheers,
Raphael
Can you log in to your customer account and check the downloads section? It should be there now.lassinger wrote:ok, buyed... but i cant find it in the downloadarea...
RayTracey wrote:Can you log in to your customer account and check the downloads section? It should be there now.lassinger wrote:ok, buyed... but i cant find it in the downloadarea...
Hello, I have the same problem.IMPICHMENT wrote:If you install a plug-in Cinema 4D in the system disk - a program breaks.
When you run the program installed on another drive everything works fine.
Might be a problem with the user. I think the system blocks the execution of files Octane, and Cinema 4D can not start.
can you try to manually copy libs32 or libs64 folder content to c4d main folder?iacx wrote:Hello, I have the same problem.IMPICHMENT wrote:If you install a plug-in Cinema 4D in the system disk - a program breaks.
- This method does not work .aoktar wrote:can you try to manually copy libs32 or libs64 folder content to c4d main folder?iacx wrote:Hello, I have the same problem.IMPICHMENT wrote:If you install a plug-in Cinema 4D in the system disk - a program breaks.
