OctaneRender® for Poser beta - build 1.11u [OBSOLETE]
gold
Ok fantastic Paul,
Seems to be working now. I had to reboot, as it was caching the old settings at first but
seems to have updated now. I assume if I get over 68 textures, in the future, a different type of fix will be needed, correct? But I imagine we will cross that bridge if we come to it. thank you.
Gold
Yes, over 68 grayscale and you'll need to delete some bump maps, or convert the floatimage nodes to image nodes (since "image" nodes are RGB, and you 144 of those) . Rightclick the plugin Materials tab tree for some options related to this. There are also a number of threads about reducing bump/trans maps in this forum.
gold
Ok thanks again Paul.
mlru
hi Paul,
I did a quick test yesterday and after a while working on a scene I was no longer able to select the material in the Plugin by clicking on it in Posers material room.
I wish, I could be more precise, but I didn't have too much time to evaluate. Here's what I did: I made several modifications to the plugin materials, stopped and started the render a few times, closed and reopened the render window and changed the camera position in Poser. Even a complete restart of the plugin didn't help. I didn't restart Poser, though.
I'll keep an eye on it if this will happen again.
Also, starting the render window collapses the whole material tree. I'm not sure, but didn't that happen in previous version?
Uwe
Win11/64Bit | GTX 4090 24GB | NVidia Driver 546.29 | Octane 4.05 | DAZ Studio 4.21
wimvdb
You said you changed camera and then the material selection no longer worked
Do you still have the camera selected in Poser? If so, it will not work. Select something else in Poser will make the material selection work again (it is in the FAQ and readme I believe).
Restarting the plugin would not help since the camera is still the active object in Poser
Configuration: Windows 11 Pro, I9 12900K, 128GB, RTX 3090, P12 b1029
Witpapier
If there is one thing I hate.... Its when poser throws out a error " poser has stopped working" when you are nearly finnished. Just blowing off steam! :evil:
RedSpec TGX for Poser / OctaneRender - OUT NOW visit http://redspec-sss.com/
mlru
wimvdb wrote:You said you changed camera and then the material selection no longer worked
Urgh - yes, that seems to be the case. Never stumbled into this before - strange.
Anyway. Fiddling with some more complex shaders I found that the "Remove Bump Maps" function won't work if you have a little more elaborated bump setting:
It has happened for a few version now, and is necessary.
Let me check this out when I add the "Change floatimage to image" function in a couple of weeks.
elenacalderas
I've just had a render restart on me after 8 hours because I changed hotpixel_removal. I don't suppose that is the way nature intended it to be, lol. (Fortunately, I had a feeling in my gut and had saved the render before I touched anything.)
Win 10 Home x64 / NVIDIA GeForce GTX 1070 8 GB / (Intel i7 2.8 GHz) x8, 16 GB RAM / PoserPro 11.2
I am 99% certain that this is happening because you use the middle mousehwheel to scroll the tree, and if the tree does not have the focus, the mousewheel instead increments/decrements the currently selected tree item. I am thinking I may have to disable the mousewheel moving of sliders, since it makes it too easy to accidentally restart a render.
If doing an 8hr render - always use progressive save. That way you can use the neat right mouseclick function on the viewport to compare with the previous render too.
Return to “Poser”
