Hi all,
We're working very hard on getting the 2.1 RC out.
As most of you will know, we will be offering release candidates to customers as of now.
We're ironing out some final problems and making sure the RC is of good quality.
If things go well, we will post it tomorrow evening (friday evening, central european timezone),
otherwise saturday.
If things get terribly bad it might be monday, but the chance for this is very small.
We've had to make quite a few changes to the render kernels to make them work correctly on the new fermi based GTX400 series,
one advantage is that we've also done some optimizations accross the board that will make the engine faster (also on other cards) in general.
Besides that, another great advantage of 2.1 is that when rendering with more than 1 GPU, you can render at higher resolutions.
eg imagine you have 1024MB video ram, and you have a scene which takes 1023 MB (eg full) with say a 1024x512 resolution film.
If you have 4 GPU's with 1024MB video ram, you can render it at 2048x1024, as the film is divided between cards.
The speedup of additional gpu's is nearly linear, so you can effectively double the speed of octane with a 2nd GPU etc...
Besides all that, this release has many new toys and a LOT of bugfixes and stability improvements.
So let's hope things go smooth for us tomorrow, and the RC is released asap.
Radiance
beta 2.1 release ETA
Thanks for these informations Rad.
Work Station : MB ASUS X299-Pro/SE - Intel i9 7980XE (2,6ghz 18 cores / 36 threads) - Ram 64GB - RTX4090 + RTX3090 - Win10
Net render : MB Asus Pro WS W790E-SAGE SE - XEON - 128GB - 2 x RTX 3090 - 3 x RTX 2080TI
WOW! So much great updates. Can't wait to test it:)
Is 4096 x 4096 still the hard upper limit of resolution?radiance wrote:Besides that, another great advantage of 2.1 is that when rendering with more than 1 GPU, you can render at higher resolutions.
Beta 2.2 will have both MLT and automatic video sequence rendering? Once that version is released, Octane is ready to be used in a serious workflow.
Windows 7 64 bit | Geforce GTX 570 | Intel i7 2600 3.9 GHz | 16 GB
- Voidmonster
- Contact:
Awesome! I'm looking forward to it!
Despite having only one GPU.
Well, I've got a second one, but my motherboard won't take it and it's missing thermal pads on all the ram so it only generates vivid random patterns...
-Zak Jarvis
Rendering with Phenom X4 9550 @ 2.20Ghz, 8 gigs of ram, Win7 64bit, GeForce GTX 260 @ 576MHz, 216 core
automatic video sequence rendering is already in 2.1. (you'll see there's many suprises in this area).Kitsune wrote:Is 4096 x 4096 still the hard upper limit of resolution?radiance wrote:Besides that, another great advantage of 2.1 is that when rendering with more than 1 GPU, you can render at higher resolutions.
the 4096x4096 should not be an upper limit.
however i can't promise anything, we need to finish some last bits and do more testing.
Radiance
- Stromberg90
Looking forward to it
Great work Radiance
Great work Radiance
Win 7 64-Bit, Q6600, Geforce 9800 GTX+, 4 GB RAM
WOT I miss THE news
ahh that's great.. gimme gimme gimme
Looking forward into this Radiance.
Vista 64 , 2x Xeon 5440 - 24GB RAM, 1x GTX 260 & I7 3930 water cooled - 32GB RAM, 1 x GTX 480+ 1x8800 GTS 512
CGsociety gallery
My portfolio
My portfolio2 - under construction
Web site
Making of : pool scene - part1
CGsociety gallery
My portfolio
Web site
