Good day!
Here is second script. It exports camera position, rotation,fov and resolution to Octane macro xml file.
Doesn't work with orthographic.
How to use:
1) select cameras you need to export.
If no cameras is selected, script will export all cameras instead.
If there is no camera in scene, it will export only resolution settings.
2)System>Run Script or Shift+F5.
Select script. Run and save as *.ocm
3)in octane import node through upper menu>Node>import Nodes
or right click>import macro.
Modo camera export script
- enverholancev
- ModoToOctaneCameraXML.rar
DOWNLOAD
================== - (2.65 KiB) Downloaded 398 times
Thanks! You are making my life so much easier with your scripts.
Windows 7 | Geforce GTX580 | i7-2600 3.4GHz | 12GB
- enverholancev
You are welcome!
Month ago i needed to render some kind of product shelf. Making them pure geometry was not a good idea. Writing numbers to a spreadsheet was pretty long.
Thanks for script!!!
Win 8.1/64 | Geforce GTX780TI | Core I7 970 | 24GB
Does this script support animation?
