Bloom and glare not working with octane camera
osmose
everything is in the title.
works correct wit standard camera
3dsmax 2011 64
windows 7 64
:cry:
Carl S.
Are you controlling the settings in the render setup panel or the camera itself?
Each camera has it's own settings independent of the render setup panel.
osmose
Carl S. wrote:Are you controlling the settings in the render setup panel or the camera itself?
hi,
i'm controlling it with the render panel.
did not see it within the octane camera parameters.
will check... :D
[edit]
ok thanks, i see it !! :oops:
cheers
Return to “Autodesk 3Ds Max”
