OctaneRender standalone 1.10 released
shadow catcher does not work anymore.
1.05 and older - worked perfectly.
edit:
I tried to reverse normals, and made a new background plane.
It does not work.
Any ideas?
edit:
It does not work.
Any ideas?
win7 64/core i7 920/32GB RAM/3x GTX 580 3GB 4x GTX 970 4GB/blender 2.79/Rhino 5,0/octane 3
win7 64/core i5-460M/8GB RAM/GTX 460M 1,5GB/blender 2.79/Rhino 5,0/octane 3 (ASUS G73JW)
Chris, it is on all the time.FooZe wrote:Hi M.Arc.In,
Are you using an HDRI?
Have you made sure you have importance sampling enabled?
Chris.
Strange, I have in my scene macromaterial, when the scene loads, and I do not touch that material everything is ok, but when i try to change it shadow catcher disables itself.
After that i can't turn it on.
In all older RC versions of Octane it worked fine.
Edit:
Ok. It works fine now.
I think it is a small bug.
When the scene loads everything is ok, but after some changes in macro materials, shadow catcher stops.
Reversing changes in materials does not help. The solution is to turn importance_sampling OFF and ON again. After that litle trick it works!
Last update, it stops after material assignment to mesh (material node) or after assignment any type of material to input node inside of macro material. When I tried to exchange material, or aply new one it hapens all the time. The solution is to turn importance_sampling OFF nad ON.
I hope, it all is clear. My english is bad, I do not know if I make myself clear enough
- amathews9518
amathews9518 wrote:Here is the files that work in 1.0 but not in 1.1
Able to use in 1.1 with no problem after this.
Textures were looking weird when model was large.
Now looks great and seems to render faster.
W764 2xE5 2650 3-780(3GB) + 780TI(3GB) Asrack EP2C602 40gb Lightwave & Chief Architect
merid888
have teh same issue here ..Ok. It works fine now.
my solution to fix it ?
just hit the reload button on teh hdri
my little wip thread :
http://render.otoy.com/forum/viewtopic.php?f=6&t=28420
