material export to Standalone Octane - help please
Timmaigh
can anyone help me out here please, i am trying to import certain scene into Octane Standalone and no matter what i do, some object are turned specular after importing, thus losing the texture which is mapped onto them in MAX...its quite a lot of objects and textures to fix this manually, so please, is there a way to force Octane to import everything as DIFFUSE? I am seriously at loss here. :evil:
Intel Core i7 980x @ 3,78GHz - Gigabyte X58A UD7 rev 1.0 - 24GB DDR3 RAM - Gainward GTX590 3GB @ 700/1400/3900 Mhz- 2x Intel X25-M G2 80GB SSD - WD Caviar Black 2TB - WD Caviar Green 2TB - Fractal Design Define R2 - Win7 64bit - Octane 2.57
mib2berlin
Hi, there are settings about obj mesh import in octane preferences.
iirc you can disable glossy and specular there.
Hit "Override settings during mesh import"
I am not at my workstation to verify but give it a try.
Cheers, mib.
GTX 760 4 GB Driver: 430.31
Octane 3.08 Blender Octane
t_3
Timmaigh wrote:Hi,
the wavefront import dialog has some checkboxes to restrict material types - doesn't this help?
ps: your footer says octane 2.57 - i can't really remember, but it is not unlikely that this version hasn't this settings. if this is the case and you for some reason need to stay with 2.57, you might still edit the .mtl file by hand. a serach and replacel to edit specular values out should be faster to get than to edit mat settings in max...
Timmaigh
Thanks for suggestions.
Limiting materials to diffuse in Octane preferences did not help. Eventually i solved it by importing the mesh from the scratch instead of reloading it inside already existing OCS, then the textures are there as they should be and the materials are all diffuse.
EDIT: I have to update my sig, obviously i dont use 2.57 anymore :D Its 1.00 version i am working now on. Need to update to 1.1.
