OctaneRender® for 3ds max® v1.02[Test]
Karba
merid888 wrote:zero with ? i don't undestand, what means that ? is just a model done into 3ds max 2009 x64, like other models, i never been had a problem like this with octanerender for 3ds max
can you orient me to know exactly the problem ?
thank you
And more over, you have set it as proxy. So whole object geometry doesn't have any valid polygons.
Why do you set all scene objects as proxy? there is no any reason for that in this case. It just makes render slower.
User avatar (Default)
merid888
hi karba, i been thinking, movable proxy is some like vraymesh, i don't been read before that, is an option of octanerender, which is the reason to add this option if the render is so slow ?
thank you i'll check all my scene, object by object, in the case repeat the same error, i mean, i'm do a bad model ? or perhaps could be a bug octanerender for max ?
in the few scenes befores i been change all objects to movable proxy without error, i think so is a problem of driver or not
i'll do test and i'll comment
thank you karba
Karba
merid888 wrote:hi karba, i been thinking, movable proxy is some like vraymesh, i don't been read before that, is an option of octanerender, which is the reason to add this option if the render is so slow ?
thank you karba
It works like vraymesh. And it make render slower in vray too.
I couldn't imagine somebody creates such geometry. So we will make geometry checking for such geometry modeling.
glimpse
thank you karba
could You coment what's the point of having geometry like this? =) I don't get here something..
and why You create the proxy if You're not replicating the object?..
merid888
thank you for explain me karba, regards ;)
hi glimpse, thank you for your comment, i think so the questioner wants to know, i'm not being rude, is just i know the maxime details about the program, that's all
cheers :)
have a nice weekend
PAQUITO
ttaberna wrote:That is not called Radiosity....it is called color bleeding and is present in real life.
Meri88 PM me with yur problem and I'll try to solve it.
Cheers
I always named that radiosity. What are the differences between radiosity and color bleeding? I assume radiosity is the fact that the light bounces, and color bleeding in an effect of the radiosity, am I right?
AMD FX8350 8 cores. 16GBs RAM
GTX690
Win8 64.
Return to “Autodesk 3Ds Max”
