OctaneRender® for 3ds max® v1.02[Test]
Karba
merid888 wrote:same result, add image
Did you press update button after changing of proxy settings?
User avatar (Default)
merid888
yes karba, if do click in movable proxy and do click ok, few objecs disapper
if i let the objet without moveable proxy they appear normal into the scene
another thing i been watched when you select the movable proxy the memoria up for example:
without movable proxy = 0.200 mb
with movable proxy 0.253 mb
why happen this ? any reason for the function of octanerender plugin ?
thank you for response and hope you can help me
regards
Karba
merid888 wrote:yes karba, if do click in movable proxy and do click ok, few objecs disapper
regards
So, if you set movable proxy, then click this button, some objects disappear?
merid888
exactly, when i do click in that option some objects disappear if i activate movable proxy, without movable proxy activate nothing happen if i refresh the scene
thank you for write me
hope you can help me with this particular case mine
regards
Karba
merid888 wrote:exactly, when i do click in that option some objects disappear if i activate movable proxy, without movable proxy activate nothing happen if i refresh the scene
regards
Can I have your scene?
[email protected]
merid888
sure i send you the file
Vanya
is it possible to do something with the "Octane viewport", until there was a new release?
can you make a visible rendering in the "working window"? or work with the camera in "Octane viewport"?
Thanks for the reply.
Core i5 76o @ 2.8o GHz | ZOTAC gtx58o AMP 1536Mb | MSI gtx46o 1o24Mb | Corsair ForceGT SSD12o | Gskill 16Gb RAM 16ooMHz
merid888
hi karba again i can't open the scene, viewport don't open, i don't know why, i think been done 2 images the last night and today i can't open it
why ?
Karba
merid888 wrote:hi karba again i can't open the scene, viewport don't open, i don't know why, i think been done 2 images the last night and today i can't open it
why ?
You scene contains a plane with zero width. Octane doesn't like it.
merid888
zero with ? i don't undestand, what means that ? is just a model done into 3ds max 2009 x64, like other models, i never been had a problem like this with octanerender for 3ds max
can you orient me to know exactly the problem ?
thank you
Return to “Autodesk 3Ds Max”
