Fooling around with snow material
suvakas
Hey all,
I was trying to create a snow material that would render fast and look somewhat OK.
I had a little fun while tweaking it. :) Models are just placeholders to preview the material and also textures are too low. But that's not important atm.
Suv
steveps3
Looks a bit like plastic but a good attempt.
(OS) Windows 7(64)
suvakas
Thanks.
You think? Yeah, probably need to tweak it a bit more. There's a thin line between plastic and snow. :)
But I kind of like the crispy look like on a very cold day.
Suv
icelaglace
I don't think it looks like plastic, it just lacks details that is all.
Snow is reflective anyway, so he's in the good way.
Suv, did you try to generate a perlin noise, maybe 1k then create a bump of this? to get the snow sparkles.
http://icelaglace.com
suvakas
Good idea!
Atm I'm only using the turbulence procedural to control the roughness value.
Suv
profbetis
Not sure if this is fast enough, but you can use SSS with the specular roughness value at like 0.8, then set absorption to a color like this (#FFBF40). Snow and ice absorb/scatter lower wavelengths like red and yellow which is what makes it so blue at large amounts.
A faster version might be to blend your glossy material with a diffuse material with transmission set high (probably all the way at 1.0 will be good) to simulate light coming through the snow subtly
GTX 1080Ti 11GB (3x), Water-cooled
Intel i7-5820K 6-core @ 3.3GHz
Windows 10 Pro 64-bit, 32GB RAM
mbetke
I can suggest the "Snowflow" plugin which does a great job of realistic snow distribution.
PURE3D Visualisierungen
dvieneira
Could you please explain how you created snow texture is it a specular map? . Looks very good
abreukers
dvieneira wrote:Could you please explain how you created snow texture is it a specular map? . Looks very good
hi, this is beginning to look like spam. please be warned...
i72630QM @ 2.00GHz | 6GB RAM | 2GB GeForce GT 540M | Win7 64bit
dvieneira
asking questions how to use software is spam now? not sure if you work with Otoy but because of you they just lost 10 licenses we were going to buy and i guess we will go with arion
Return to “Works In Progress”
