Saved Frames
profbetis
Many times I will finish a render and color correct it many different ways and save each as an image just because I know if I want to have a different color correction later, I'll have to re-render it again just to have a different color correction.
I wish that with the .ocs file, you could save frames of completed renders as raw data that you could open up and re-process. It would be just like pausing a render and changing the processing parameters. What if I decide the 10 images I just rendered have too much glow or not enough dynamic range? I shouldn't have to re-render those... octane already knows how to handle its own raw data, and I think we should choose to be able to come back to those later.
On a related note, it would be cool to be able to do a "Continue Render" if we saved the scene in a frozen/locked state to be opened later and continued on the same or a different machine.
Thoughts? :)
GTX 1080Ti 11GB (3x), Water-cooled
Intel i7-5820K 6-core @ 3.3GHz
Windows 10 Pro 64-bit, 32GB RAM
