OctaneRender® for Maya® v1.0 RC3c beta [OBSOLETE]
Moderator: JimStar
JimStar
Otoy® is proud to announce the availability of a new version of OctaneRender™ for Maya®
Maya® Version Requirements
This release will work with Maya® Versions 2011, 2012, 2013 and 2013.5 / 32-bit & 64-bit on MS Windows operating systems.
Notes regarding features/functionality
OctaneRender™ for Maya® implements almost full functionality of OctaneRender™ standalone inside Maya®. Materials from the Live DB are currently not available.
To run OctaneRender™ for Maya®, you need to also have an activated OctaneRender™ Standalone copy activated on the machine you wish to install the plugin onto.
You cannot purchase and use only the Maya plugin and use it without also owning an activated copy of OctaneRender™ Standalone on your machine
HOW TO PURCHASE LICENSES
Go to our online shop here: http://render.otoy.com/shop/
If you do not own an OctaneRender™ Standalone Edition License yet:
You can purchase both the OctaneRender™ Standalone Edition and the OctaneRender™ for Maya® Edition as a reduced price bundle, purchase the bundle priced at 279€
If you already own one or more OctaneRender™ Standalone Edition licenses you want to pair the plugin with:
Purchase an "OctaneRender™ for Maya® Beta License" priced at 99€
You can also purchase a 3, 5 or 10 pack of OctaneRender™ for Maya® licenses,
just like OctaneRender™ Standalone Edition packs.
OCTANELIVE
Just like OctaneRender™ Standalone, the Maya® plugin product also needs an additional OctaneLive license and be activated on a machine.
This has to be done in the plugin interface panel in Maya, and is covered in the included PDF manual.
It can only be done after an OctaneRender™ Standalone license is already activated on the machine in question.
BUG FIXES SINCE LAST RELEASE:
  • Fixed "Caustic blur" attribute which did not affect the render when changed.
DOWNLOAD
Next version HERE.
Yours,
The OctaneRender™ Team.
Elvissuperstar007
super
jmfowler
Jimstar - thanks!
Elvis - I thought you were a max user?
Maya 2013 / W7 64bit / Intel i7 980 / 24GB / Gigabyte gtx 580 3GB + 2*EVGA gtx 680 4gb / MB Gigabyte X58A-UD3R / NZXT Phantom - white/black case
Maya 2013/W7 64bit/Intel i7 3820/16GB/ MB Gigabyte GA-X79-UD3 /4*EVGA gtx 680 4gb/SSD 6Gb.s /CM HAF X case
Elvissuperstar007
jmfowler wrote:Jimstar - thanks!
yes I'm using max) but the development in Maya I wonder
skywxp3d
For some reason, since about 3 versions ago - I cannot use both GForce cards - I get this out of memory crash...
- Now it seems I'm crashing on just one card, and its a dead simple scene!
CUDA error 999 on device 0: An unknown internal error occurred. -> Failed to launch kernel (pmc)CUDA device 0: PMC failed
// Error: Octane: render failure, stopped //
Sky Kensok
jacobkolady
Hello Guys I just updated my maya plugin to this version and now when i render I get this error.
Octane: Error mesh export. Octane render stopped.
Can someone help me with sorting this out. The scene was rendering perfectly with the previous plugin.
Thank You
JimStar
jacobkolady wrote:Hello Guys I just updated my maya plugin to this version and now when i render I get this error.
Thank You
Post all export log please.
TBFX
JimStar wrote:Fixed "Caustic blur" attribute which did not affect the render when changed.
Thanks JimStar, this attribute now works but I still have to refresh an IPR session to see it update. in the standalone changing it forces a refresh.
I have checked and I don't seem to be having the batch rendering issues others are having.
T.
Win10 x64|i7-9750H 2.6 GHz|32 GB RAM | RTX2080 max Q 8GB
jmfowler
skywxp3d wrote:For some reason, since about 3 versions ago - I cannot use both GForce cards - I get this out of memory crash...
what cards are you using together?
Refracty
I have a question regarding to the animation modes.
I have a scene that contains only camera and texture animation.
If I set the scene to Camera Animation only the textures are frozen.
I need to render this out quick - So any voxiling will make the goal to reach the deadline impossible.
Isn't it possible to to set the animation mode to "camera movement" and still have the animated texture updates possible?
That would be perfect.
Return to “Autodesk Maya”
