teddy-bear
Elvissuperstar007
PMC 16
2012 x 1324
filter 1.0
3ds max in millimeters
octane render Standalone v1.00 in millimeters
460+580GTX 20 min
Last edited by Elvissuperstar007 on Sat Dec 08, 2012 3:07 am, edited 1 time in total.
temp-64GTX
Реквестую педобира.
Win7 x64, [email protected], 32Gb DDR3 1600, 2xGTX580 3Gb, Corsair 64Gb SSD, ViewSonic 2560x1440
clintond
I was curious to see what type of renders you were capable of, given the very short and non-constructive comments you make of others work.
- No sense of lighting.
- The wall texture is too bumpy, also the bed head texture.
- There is no indentation from the teddy on the bed.
- Fabric texture has far too much diffuse along the oblique normal.
Otherwise, not bad :)
acc24ex
pretty nice, maybe a bit too much falloff
3rdeye
I love the render though...
Populus
Awesome work on the fabric textures! Overall its a very good scene that deserves better lighting, try add more mood perhaps by letting in some evening or morning sunlight?
win 7 x64 / i7 920 / 12GB / gtx 470 + gtx 480
neo83_gr
The fabric is made with instancing? It looks like displacement (but it's not supported).
sdwhitton
think it all looks very good, maybe the plaster wall on the far right is too much bump map,
but if it is meant to be bumpy then maybe the junction with the wallpaper should be more bumpy or rough, if that makes sense
workstation well past its sell-by-date, Vista 64 bit (!) with a pitiful amount of RAM, re-invigorated with a GX 590
3ds Max Design 2011 (have 2013 but can't be bothered to re-do all the UI), CS5, and that free z-brush program, whatever it's called
jmfowler
Looks great Elvis!
Is that your bed? hehe.
Maya 2013 / W7 64bit / Intel i7 980 / 24GB / Gigabyte gtx 580 3GB + 2*EVGA gtx 680 4gb / MB Gigabyte X58A-UD3R / NZXT Phantom - white/black case
Maya 2013/W7 64bit/Intel i7 3820/16GB/ MB Gigabyte GA-X79-UD3 /4*EVGA gtx 680 4gb/SSD 6Gb.s /CM HAF X case
iViz3D
Great work! I like the overall composition except that Teddy bear posing is quite stiff, need a little bit of posing resulting to its material softness. Bump mapping is also much highlighted for the wall and headboard.
