No "Octane properties" in german Interface
cfrank78
A guy in facebook wrote me how to use movable proxies. I wanted to try it, but when i right clicked i had no "Octane Properties" in the flyout menu. I started 3DS in english and it showed up. I started german again and no "Octane properties". I tried to reset Autodesk to its defaults and still no success!
Can anybody help please - for now i work in english autodesk version, but its very hard for me.
Help is very appreciated - thank you very much -
Kind regards Chris!
Karba
cfrank78 wrote:A guy in facebook wrote me how to use movable proxies. I wanted to try it, but when i right clicked i had no "Octane Properties" in the flyout menu. I started 3DS in english and it showed up. I started german again and no "Octane properties". I tried to reset Autodesk to its defaults and still no success!
Kind regards Chris!
What octane version do you use?
Did you select Octane as render?
cfrank78
Hi Kaba!
It´s all in my Signature. I use the final version. Of course i selcted Octane as Render Engine. It works without problems in english interface, so in french and so on. Just german does not display it!
Kind regards Chris!
Karba
Hi Kaba!
Kind regards Chris!
Well, I can't check it. I have only english 3dsmax. Do you have any other such menu issue with german 3dsmax?
cfrank78
Well, I can't check it. I have only english 3dsmax. Does you have any other such menu issue with german 3dsmax?
Kaba - normaly 3ds is delivered in many languages. just go to your start menu/all programs/autodesk/autodesk 3ds design 2013 64 bit/Languages .
There you should find all kind of languages. Start for example french, or german.....it is in all languages just not in german. I have also Vray in my flout meny - works without problems. never had any issues in my fly out menu - just octane does not show up! I try to make a screenshot and add! Will be in this reply in a few minutes!
Karba
Thank you for the tip.
Will check it.
cfrank78
Here are the promised screenshots - should be clear now!
i allready tried to set max back to its defaults and i also did a complete reset - with no success. i also tried it on another compter - same result. seems to be a bug?
Thanks for your help!
Chris!
cfrank78
Any News Karba?
cfrank78
As i said it is very hard for me to work in english Interface!
Karba have you found out anything? Or anybody else - have you any idea what i can try to get this to work? I really need movable proxies!
Thank you - kind regards Chris!
Karba
cfrank78 wrote:As i said it is very hard for me to work in english Interface!
I am sorry. I can't fix it immediately. I need to finish some other stuff first.
Return to “Autodesk 3Ds Max”
