MOI3D to Octane Tutorial
Post, discuss and share handy resources like textures, models and HDRI maps in this forum.
Locked
PhilBo
I threw together this tutorial to assist in MOI3D users to get their meshes out of MOI3D and into Octane Render properly. This doesn't rely on high poly meshes or smooth groups but in fact uses the high quality vertex normals from MOI3D.
Thanks for looking.
Phil
MOI3D_to_Octane_Tutorial.zip
(1.22 MiB) Downloaded 824 times
Win7 64| Two GTX 470s | Phenom II 920 | 8 GB
Win7 32| GTX 260 | Athlon X2 5000+ BE | 2 GB
Son Kim
thanks for the tutorial - i found it useful!
question about units in Moi3D, what units should you set it to when working? would you set it in inches when working on something like a small toy?
PhilBo
Actually, you need to scale the objects. Changing the unit setting in MOI3D does nothing.
If you make a 1 x 1 x 1 cube and set the scale to "inches" in MOI3D and export, it will end up being a 1 x 1 x1 meter cube in Octane. There are no units in the OBJ file so the units get lost. It ends up being a 1 x 1 x 1 in the OBJ file with no units.
So you either need to shrink the geometry in MOI prior to export, or use the settings in the import dialog box in Octane.
Sam
Wow... I learned something very important here
Thanks for the clean and well explained tutorial ;)
http://Kuto.ch - Samuel Zeller - Freelance 3D Generalist and Graphic designer from Switzerland
Son Kim
Wait, if the units get lost how would scaling the object in Moi scale down the object in Octane, since Octane turns it into a 1 meter cube again upon import? There's probably a simple answer to that, i feel dense today..
BTW does Octane have any issue with rendering high valances vertices(i.e. 8,9,10,etc)?
radiance
i moved this topic to the resources forum so everyone can view it and left a shadow topic here...
Radiance
Locked
Return to “Resources and Sharing”
