Batch render dont work
Moderator: JimStar
JimStar
roryoctane wrote:JimStar
I have tried the deactivation and reactivation - no luck
and as I said before, this hasn't even been installed elsewhere !
- Have you the same activation errors right after Octane is started?
- What do you see in the "OctaneLive Account" tab of Octane settings, can you make the screenshot?
- Does the IPR render work (do you see the rendered image in the RenderView)?
roryoctane
Jimstar,
There are no errors on Octane startup .
Renderview and IPR work perfectly.
Rory
JimStar
roryoctane wrote:Jimstar,
Rory
And do you still have the same lines in batch output?
Error: line 1: Error starting Octane engine: This account is currently activated on another machine. Please deactivate it on the other machine first and wait 30 minutes before re-activating it on this machine, or activate another account/license on this machine.
Error: line 1: Error activate Octane engine: This account is currently activated on another machine. Please deactivate it on the other machine first and wait 30 minutes before re-activating it on this machine, or activate another account/license on this machine.
Or is it something else error now?..
roryoctane
Jimstar
I managed to get it to work -
Chris on Support got me to try a beta Octane - that still didn't work,
but when I tried the beta plugin - it all worked.
So it seems that the release version of both are not working together ?
So for the meantime I have reverted to the last Beta of both.
Not ideal but it works
Rory
johnb4467
Hi Rory,
Could you maybe let me know what version of the standalone and maya plugin you are using (that works for batch rendering)? I'm having the same issue, and would love to be able to work while they resolve the issue.
Thanks so much. :)
John
roryoctane
johnB,
it was Maya Plugin 3.03g Beta,
and Standalone 2.58e
Rory
johnb4467
Thanks for the reply, Rory.
I'm not sure where to grab those versions...I looked for the older version of the Octane Standalone in its respective area, but the closest I could find was 2.58d.
Also, I can't seem to locate any older versions of the Maya plugin, as they all just say "next version here", or something to that effect.
Did you have to contact support by some means to get links & get up and running?
roryoctane
johnB,
Standalone:
http://render.otoy.com/forum/viewtopic.php?f=24&t=21850
I also can' tseem to find it, maybe Jimmstar can help ?
Rory
Demious
I'm having the same issue:
Result: C:/3D Project Folder/Dust/scenes/Dust10Piece_01_Dyn_Ver003_BAKE_002OCT__468.mb
Error: OctaneRender is not activated!
Warning: file: C:/Program Files/Autodesk/Maya2013/scripts/others/mayaBatchRenderProcedure.mel line 599: Renderer returned an error while rendering 'defaultRenderLayer', please verify the output image.
Scene C:/3D Project Folder/Dust/scenes/Dust10Piece_01_Dyn_Ver003_BAKE_002OCT__468.mb completed.
Warning: line 1: Preferences are not written in batch mode
Using latest release of standalone and plugin.
No issues doing single frame or IPR rendering.
No issues with standalone renderer.
Using Win 7 64bit
Intel i7 860 @ 2.8GHz, 8.00 GB, GeForce GTX 480 (x2), Windows 7 (64) {+2 shelved 680's waiting for Kepler support ;)}
JimStar
Demious wrote:I'm having the same issue:
Using Win 7 64bit
Try to do what I described in this post please: http://render.otoy.com/forum/viewtopic. ... 05#p114705
Return to “Autodesk Maya”
