First harder test
JackMcRip
What can I adjust better for a nicer result?
Pathtracer with environment lightnigt.
Because the window is to small I give the top of the room a very little bit of emission.
Some models and textures I must make new.
The cloth in the front, left is awful...
"All you need to live a wonderful life" ;)
C4D + ZBrush User
Use AMD Phenom 9850, GeForce 8600 256MB, 8GB
jmfowler
haha funny image!- you need to PMC this render for a long time with 16 bounces - probably need at least 12000 samples.
Maya 2013 / W7 64bit / Intel i7 980 / 24GB / Gigabyte gtx 580 3GB + 2*EVGA gtx 680 4gb / MB Gigabyte X58A-UD3R / NZXT Phantom - white/black case
Maya 2013/W7 64bit/Intel i7 3820/16GB/ MB Gigabyte GA-X79-UD3 /4*EVGA gtx 680 4gb/SSD 6Gb.s /CM HAF X case
roeland
Try to use sky portal geometry inside the window. See http://refractivesoftware.com/forum/vie ... =21&t=7210 for how portals work.
The basic steps are:
• You first have to remove any glass modeled in the window.
• Then you have to cover the openings in the window with sky portals. These are single-sided polygons with the normals pointing inwards. Putting a separate quad in every slit in the window will give the lowest noise, but just covering the window with one quad will still work better than not using any portals.
• The portal geometry should have a separate material ID. You have to assign the portal material to this material ID in Octane.
Roeland
artmaknev
hehehe, the title should be "NYC apartment" occupied.
Return to “Works In Progress”
