First Render
Met
First time for render work, I like it.
But have a question about hot pixel how I can fix it.
Another question is if I use image in Texture environment for background. Its doesn't have shadow on building. It's have the way to make background with image and still have shadow too or not.
Elvissuperstar007
use PMC
Met
Thanks Elvis I'm change to be Pmc and its all clear.
For Maxdepth I'm just think if have more its increase quality but now I'm should go to read manual again.
Met
And these I'm retouch from my first pic.
Elvissuperstar007
Spin the axis trees
sdwhitton
target 'Y" needs to be same as camera 'Y', and then use shift on the camera to bring the horizon down..?
not sure needs to be rendered with PMC too, can get great results with just plain Direct Lighting?
workstation well past its sell-by-date, Vista 64 bit (!) with a pitiful amount of RAM, re-invigorated with a GX 590
3ds Max Design 2011 (have 2013 but can't be bothered to re-do all the UI), CS5, and that free z-brush program, whatever it's called
Met
Thanks to elvis again agree with you. I'm try to retouch on right hand corner but don't have idea to put something to make a pic better.
Thanks to Sdwhitton i'm try tomorrow, now i'm don't sit on my computer and i'm not understand about target camera.
kavorka
you probably don't even need 16 bounces. For interiors, you need more bounces cause most of your light is indirect, but with exteriors, you could bring it down to like 10. Do a test and see if the quality is the same.
Even for interiors, you shouldn't need more than 16 bounces.
Elvissuperstar007
Return to “Works In Progress”
