layering materials
Refracty
Does anybody know if layering textures with alpha information is somehow possible.
I want to put a colorful text onto a metal surface. The map with the typo comes with alpha transparency (png).
I want to stack it onto a metal material.
Of course you could do it in photoshop and then apply the combined map, but I would prefer to to the texture comp in Octane.
Is there a way to do it in Octane?
matej
Just load your image as alpha texture, this will give you a grayscale map in Octane, you can use for mixing other textures or materials.
cgmo.net
JackMcRip
I have the same problem.
But I dont know where I can add textures.
In the node editor?
In the attribue editor of a material.
For layering is to use Mix-Material?
Is there a tutorial?
C4D + ZBrush User
Use AMD Phenom 9850, GeForce 8600 256MB, 8GB
steveps3
I would say that if you don't know how to add textures then layering is the least of your worries. I'd learn the basics before going on to more complex stuff.
This should get you started
http://render.otoy.com/forum/viewtopic.php?f=21&t=7566
(OS) Windows 7(64)
JackMcRip
Thats a lot of good stuff :-)
Maybe I found the solution with it.
I have found the manual at the homepage (in the downloads). Maybe it will help, too.
C4D + ZBrush User
rosol
This is my first post so: Hello everyone
As to the subject maybe this helps
Refracty
ahh, it is so simple :roll:
Thank you matej and rosol for the clarification.
