OctaneRender™ Standalone v1.00 (obsolete)
roeland
Hi all,
Octane version 1.00 is now available. Apart from a few small bug fixes this release is the same as RC 3. The new features like glare and bloom will be available in the next version.
Changes since 1.00 RC 3:
  • Fixed decreased rendering speed after disabling all emitters in a scene.
  • Better UI performance when big scatter nodes are selected, or when a mesh node with lots of input pins is selected.
  • Fixed behavior of cancel button of save dialog.
  • Fixed aspect ratio bug when specifying a resolution on the command line.
  • The Linux version can locate the octane.dat file when the path to octane contains non-ASCII characters.
Downloading:
From now on the downloads for (stable) commercial releases will be available in your customer area in the Downloads section.
Roeland
User avatar (Default)
merid888
thank you roeland, question:i have the rc3 installed, what is the next step ? i need erase this version or rewriter the new ? becouse i see 2.58 and 1.00 ?
regards
GeoPappas
roeland wrote:Octane version 1.00 is now available.
Please add a zip version.
gabrielefx
from 99€ to 199€...
for Max users 349€ one single license without distributed render
Vray-RT 2.0 1 workstation license + 10 nodes 960€ (rt-gpu works on networked workstations)
because we Max users need to activate 2 softwares, the standalone and the Max plugin for each workstation then 10 license costs
1799+1799 = 3598 €
I think it's time to develop a network license system for multiple networked gpus and a Max plugin full compatible with Backburner.
For multiple gpu workstations now Octane for Max is not cheap anymore.
erges
HI, Now It works with kepler on its full performance? I meane CUDA 512 of Fermi = CUDA 512 of Kepler ? Or its still slower then Fermi .
The matter is I think what video card to buy now ?!
Thank you
Elvissuperstar007
OctaneRender 1.0 final BUG!!!
Sun does not work anymore! do not miss the glass
https://vimeo.com/54450252 VIDEO
another bug with importing! if you specify in octane millimeters, objects do not
3ds max set to millimeters
Last edited by Elvissuperstar007 on Wed Nov 28, 2012 2:58 pm, edited 2 times in total.
Elvissuperstar007
ctr+z it was necessary to add to the final release )
alien_60
Elvissuperstar007 wrote:ctr+z it was necessary to add to the final release )
+1
alien_60
where ctr+z? :o
merid888
i have a problem i don't know recognize the values 0 or 1 ? where i should change this values ?
i add image, thank you if you can response me karba
Return to “Commercial Product News & Releases (Download here)”
