OctaneRender® for Poser beta - build 1.00n [OBSOLETE]
This is the recommended thread for downloading, and posting any questions, suggestions or support queries for OctaneRender for Poser, build 1.00n.
In the unlikely event that you have a support issue, pls provide the following information:
- Operating System (ie. Win XP, Vista, 7, 8)
- 32 or 64 bit
- Amount of RAM
- Nvidia driver version
- Poser version (Poser -> Help -> About Poser) - list the build number (eg. 9.0.3.23027)
I will be posting updates to the plugin as required, which will be reported in this thread.
Change Log
- Props which have no uv mapping (ie. some glass objects) can now be loading into the plugin.
Links
- Features Video
- Features Blog Posting
- Introductory Tutorial
- Facebook Page
Troubleshooting
- GUI issues (lock-up/crash) on large scenes (ie. 4million polys) - potentially due to the Windows Vista/7 "Timeout Detection and Recovery" http://msdn.microsoft.com/en-us/library ... 87368.aspx. Settings can be changed using Regedit. The recommended setting for Octane are registry setting HKLM\System\CurrentControlSet\Control\GraphicsDrivers, TdrLevel = 3, TdrDelay =10 (if these settings are not already there, rightclick the right panel -> New -> DWORD). You will need to reboot after changing these settings.
Limitations
- Loading a Poser scene by double-clicking a pz3 file in the Windows file explorer, or selecting from your "Recent Files" will not load the previously saved Octane scene data for that file when Poser starts. This is due to a Poser bug which has been reported to Smith Micro. Instead, use the Poser menu File -> Open to open any pz3 files which contain Octane scene data.
- Material Picking (by clicking on a material in the Poser Material Room) does not select that material in the OctaneRender material tab if you have a camera selected in the Parameter Dials window.
Download the plug HERE
Hope you enjoy using the plugin!
Galatea
I've downloaded the current build 1.00n from the link provided and copied the files to the correct locations as per the instructions given in the plugin's manual. When I launch the plugin from Poser the plugin version still shows 1.00m and not 1.00n, is there any reason why this is happening?
- Operating System: Win7
- 64 bit
- Amount of RAM: 16Gb
- Graphics Card: GT440/GTX 560
- Nvidia driver version: 306.97
- Poser version: 9.0.3.23027
Win 8.1 x64 | i7-6700 | ASRock Z170 OC Formula | GTX 980 TI 6GB | GTX 980 4GB | 32Gb RAM
vipvip
hi,
is this plugin compatible with poser pro 12 and what is the cost ?
thanks
wimvdb
Galatea wrote:I've downloaded the current build 1.00n from the link provided and copied the files to the correct locations as per the instructions given in the plugin's manual. When I launch the plugin from Poser the plugin version still shows 1.00m and not 1.00n, is there any reason why this is happening?
- 64 bit
Mine says 1/00m as well. I overwrote the old one and the size of the addon itself was different and newer. So I think Paul forgot to update the version number
Configuration: Windows 11 Pro, I9 12900K, 128GB, RTX 3090, P12 b1029
Galatea
- 64 bit
That is a plausible explanation.
Galatea
I receive an error when attempting to launch the plugin when certain objects are included in a scene. I've successfully launched the plugin with a primitive loaded into the scene.
- 64 bit
Yes to the compatibility question (assuming you meant "2012"). Cost details at http://render.otoy.com/forum/viewtopic.php?f=7&t=25193.
Galatea - would it be possible to email the prop to me at [email protected], and I'll find out what is causing the issue.
Correct. I have re-uploaded the file. Pls re-download and install. Only the OctanePlugin.pyc file has changed.
Skydomes
Some Poser scenes use Skydomes for image based lighting. This will work in Octane, however you may need to use Snarlys subdivider script on the skydome to get a good enough polygon density to ensure you don't get smoothing issues.
And much better solution is to simply use the Octane "environment" node. This is in the Render Options List on the Settings tab. Set the "environment" to "texture environment". Then set the "texture" to the skydome map (assuming it is a support HDRI layout). Remember to make the skydome Invisible in the Poser scene.
Return to “Poser”
