Animation resolution
3form
Hi All
I am making an animation and rendering at 2400X1600 its a short fly in 50 frames @ 24FPS. When I playback the animation it says in the info its 720X480 I have checked max settings and octane settings all are 2400X1600. Is there a maximum animation size for octane? Hope someone has the answer! ;)
cheers
J
GTX670 4GB, GTX460 2GB, Q8400 2.27Ghz, 6GB RAM
Karba
3form wrote:Hi All
cheers
J
I tried 1280x720. It works fine. I don't think there is such limits.
Newman
I rendered 2048x1024. Works fine.
Sorry for my bad English
Win 8 PRO x64/ Core i7 950 / 16gb RAM / GTX 460/ GTX670/
JuM
there is no limitation its same with single frame render.
3form
Thnks ill check my settings again ;)
gueoct
I guess this depends of your output file format. What is it?
Intel i7-970 @3,20 GHz / 24 GB RAM / 3 x EVGA GTX 580 - 3GB
3form
compress dvi
3form
Thanks for the info still no go prob have to reinstall max. My prev renders worked well must be a bug with max. :evil: :?: :!: :roll:
cheers
suvakas
3form wrote:compress dvi
What's that?
If you mean DV, then it doesn't support resolutions greater than 720 (PAL).
Also you never ever want to render directly to compressed format. Only for previews maybe.
Render out as image sequence and do your compression later.
Suv
3form
thnks suv ill try that :o ;)
Return to “Autodesk 3Ds Max”
