Here is a quick fix for x64.
Replace the Soft2Octane_x64.dll from the C:\Users\XX\Autodesk\Softimage_XXX\Addons\Soft2Octane\Application\Plugins\bin\nt-x86-64 folder with the one from the zip file.
face
Soft2Octane 3.03 [Obsolete]
http://vimeo.com/user2509578
The frames appear to finish correctly, however the plugin does not seem to advance the timeline. It just renders the first frame of the animation over and over.
SetValue("Soft2Octane.start", 50, null);
SaveScene();
// INFO : Starting Renderengine
SaveScene();
Sorry, my error.
It was build 5min. before my trip to work
face
face
- Soft2Octane.zip
- (201.07 KiB) Downloaded 504 times
I got two different ICE clouds each with its own Octane Scatter.. But I only get one them actually writing out a .obj/.scv file and the other one is ignored? Is there any workaround for this? Seems also my particles are now flipped in the direction :O
/regards Peter K
/regards Peter K
Win7, i7 980 Hexacore, 24GB RAM, 3xEVGA SC 670 GTX 4GB
The flipped issue is solved but i don´t know why one pointcloud is ignored.
If the Set Octane Scatter compound is set in each cloud to true, it should export a csv file for every cloud.
Have test it with a duplicated cloud where the second has an other shape and an other speed.
Try to use this dll for x64.
face
face
- Soft2Octane_x64.zip
- (201.18 KiB) Downloaded 462 times
Hi Face,
I'm having some problems installing this latest version on Softimage 2011. The dll seems to be the cause (appears in red in the plugin manager). I tried to replace the dll with the one you're providing on page 2 of this thread but doesn't work either.
When I try to access the plugin through the toolbar menu I get the following error:
Can you help me?Application.SIAddProp("Soft2Octane", "Scene_Root", "siDefaultPropagation", "Soft2Octane", "")
# ERROR : Invalid procedure call or argument: 'SIAddProp' - [line 18]
# ERROR : (Microsoft VBScript runtime error)
# ERROR : [16] (null)
# ERROR : [17] function gen
# ERROR : >[18] SIAddProp "Soft2Octane", "Scene_Root", siDefaultPropagation, "Soft2Octane"
# ERROR : [19] inspect
# ERROR : [20] end function
Win7 Pro x64 | GTX 770 2GB + GTS250 512Mb | Intel Xeon i7 4x 3.4ghz | 16 GB ECC Mem | Intel SSD 520 | Dell 27"
SOFTIMAGE l 2011 + OCTANE V1.20
When the dll is red, they isn´t loaded.
Have you installed the Microsoft Visual C++ 2010 x64/x86 Runtimes and Redistributeables?
face
face
