Please post here any bugs and crashed you have with RC2
In case of crash please explain what actions you did before.
RC2 bugs and crashed report
- MaTtY631990
there is bug with the OctaneLight (sphere) with visability on. When this is set as a proxy it causes illumination problems. With visability off its fine. It's just this one, other light types work fine.
- MaTtY631990
- MaTtY631990
The scene is set to meters and is a size 0.01. Its roughly 3 meters across just off to the left and right of camera. I have also attached this scene setup just in case. I am using 3dsmax 2011.
- OctaneLight test.zip
- (150.6 KiB) Downloaded 204 times
Just tried your scene, no any light issue.MaTtY631990 wrote:The scene is set to meters and is a size 0.01. Its roughly 3 meters across just off to the left and right of camera. I have also attached this scene setup just in case. I am using 3dsmax 2011.
Are you sure you use RC2 version?
- MaTtY631990
Yes, are using the RC2 version. I used 3dsmax 2011 64bit for this setup. As soon as open the viewport window I get result from same as render. Maybe if anyone else is using same 3dsmax version as me could post results, can confirm this.
