Octane bloom effect
- Elvissuperstar007
- Contact:
Please add the bloom effect in RC3 3ds max
awesome!
Maya 2013 / W7 64bit / Intel i7 980 / 24GB / Gigabyte gtx 580 3GB + 2*EVGA gtx 680 4gb / MB Gigabyte X58A-UD3R / NZXT Phantom - white/black case
Maya 2013/W7 64bit/Intel i7 3820/16GB/ MB Gigabyte GA-X79-UD3 /4*EVGA gtx 680 4gb/SSD 6Gb.s /CM HAF X case
finally thanks!
Intel Core i7 920 @ 2.67GHz, 6.00 GB, 896 MBGeForce GTX 260 (x2), Windows
RIBS_stairs
http://www.refractivesoftware.com/forum ... =5&t=17973
RIBS_stairs
Pretty cool, major improvement in quality in overbright areas
Win 7 64bits / Intel i5 750 @ 2.67Ghz / Geforce GTX 470 / 8GB Ram / 3DS Max 2012 64bits
http://proupinworks.blogspot.com/
nice, looking forward to this
- LudovicRouy
- Contact:
Is this a post-production effect, ie. can be tweaked when rendering is stopped / finished, or needs a render restart? If its an integral part of rendering, can it be disabled for the times you don't need it (and thus probably save render time)?
Looks nice, but I hope Octane is not going to become bloated with post-production effects that cant be toggled off, and thus loose it's main advantage - render speed.
cgmo.net
cgmo.net
It's part of the tonemapping and can be tweaked anytime, i.e. also while rendering is stopped (similar to changing exposure/saturation/gamma/vignette...). It will slow down the tone-mapping which is executed every viewport refresh (5 second interval), but can be turned off while rendering and turned on at the end. On the other hand it's still fast enough that I expect people not to bother switching it off.matej wrote:Is this a post-production effect, ie. can be tweaked when rendering is stopped / finished, or needs a render restart? If its an integral part of rendering, can it be disabled for the times you don't need it (and thus probably save render time)?
Please keep in mind though that this is just a preview and there is still quite a bit of work to be done.
Cheers,
Marcus
Thanks Marcus, sounds great. The usual workflow will probably be to apply bloom when rendering is finished, so its handy that it can be turned on / off.
cgmo.net
cgmo.net
