Hi again,
I imported an obj to the scene with its materials but only occulison map is seen on the screen. I can not see the materials of the model. Will you please help me?
Where are the materials of the model?
Check out if you see multiple input dots on your mesh node. each dot represents one material. then click the meshnode and adjust the material settings on the right side of the user interface. Alternativle you can create material nodes and link them with the mesh node by draging connections from material output dot to meshnode material input dot.
If there is only one dot visible you have to create and assign the material accordingly in your 3d host app.
