use instances ?
Hamed.Mojtabavi
hi
is there any one here that can use instances ? and how??????
mib2berlin
Hi, you need a release candidate version of octane, latest is 3.03.
Tutorial:
http://www.youtube.com/watch?feature=pl ... PsGuKA3dZY
Some exporter supports instances, blender do for example.
Cheers, mib.
GTX 760 4 GB Driver: 430.31
Octane 3.08 Blender Octane
Hamed.Mojtabavi
mib2berlin wrote:Hi, you need a release candidate version of octane, latest is 3.03.
Tutorial:
Cheers, mib.
tanx alot mib2berlin
Do you know how to use it in max ? is that like regular instaces in max?
For Octane Standalone, load the mesh you want to instance into an objects->mesh node. Then plug that node into a objects->scatter node. Plug the scatter node into the mesh pin of the rendertarget node. You will need to add at least one transform to the scatter node.
The transform is a position, scale and rotation matrix (only the first 3 rows of the 4x4 matrix). You can either make a transform matrix by hand, or generate one (not via Octane Standalone). I'm not a 3DS Max person, but I understand you can use the scatter plugin to generate the transform matrix. The OctaneRender for Poser plugin will generate the transform for you too.
vanhage
Hello,
I've spent a few hours looking into creating an automatic scatter node matrix exporter to generate all the transforms parametrically using Rhino5/grasshopper and save them out as a txt file to automate things like foliage and entourage in Octane. I have some questions/observations that hopefully someone can shed some light on.
-I tend to work in mm, but it appears that all the camera controls and matrix inputs for the scatter node are in Meters? I would have thought that when you set the obj import units, those units would be the units for the file, guess not.
-Is there a way to swap the Y and Z axes for the coordinate system so that Z is up? I work mostly in rhino and grasshopper and all my transformation matrices are generated XYZ, NOT XZY.
-Correct me if i'm wrong, but it seems like the Z axis is working backwards. When I input values in the scatter node I have to input a negative value for Z to get it to move in the positive direction. I know this is the case in computer graphic software like processing, but I've never seen it in a 3d program. Am I missing something?
~Vanhage
Win 8 64 | 2X Geforce GTX680 | i7-3770K Ivy Bridge 3.5GHz | 32GB
Octane works in metres, so the transformation matrix needs to be in metres.
If you are NOT using the daylight environment, you can re-assign the "up" vector of the camera to compensate for this (set up to 0, 0, 1). However ideally you should transform your transformation matrix such that Octane X = Rhino X, Octane Y = Rhino Z and Octane Z = Rhino Y (or maybe -Y). Whilst that is simple for vectors, it may be tricky for the rotation matrix part of the transform. I convert EVERYTHING to the Octane axis system before applying quaternions/rotation matrices. So if you have a plane that your transforms will be placed on, convert the Rhino coord system to Octane XYZ prior to applying any rotations you need. Good luck!
newske
I use scatter from Rhino frequently.
A short python function for this would be:
def XFormFlipYZ(matrix):
XBasis= rs.XformChangeBasis2((1,0,0),(0,1,0),(0,0,1),(1,0,0),(0,0,1),(0,-1,0))
return(XBasis * matrix)
This will map Rhino Z to OBJ Y
Octane for Rhino | Windows 8.1 x64 | i7-3820 OC | GTX970 4GB OC & GTX 560 Ti 1GB OC | 32GB DDR3
Return to “Commercial Product News & Releases (Download here)”
