playing with instances octane for 3ds max
- archigrafix
Are you meaning that 3Dmax instances or proxies are interpreted automaticly as Octane instances??? As a Sketchup user I would so much need that sort of tool...
- jan kudelasek
- Contact:
archigrafix wrote:Are you meaning that 3Dmax instances or proxies are interpreted automaticly as Octane instances??? As a Sketchup user I would so much need that sort of tool...
No, I mean that 3ds max instances are turned to octane movable proxy.
W7 / Quad Core Xeon E5405 / 24G / Asus ENGTX 480, 580 / http://www.allcity.cz / https://www.facebook.com/pages/Allcity/ ... e=bookmark
great vegetation !! I love the render
mbetke wrote:FOrest Pack Pro works well with Octane. You have to use the FOrestTools and make all forest objects to instances and then select all the stuff and make it a movable proxy.
Can you expand on this. I am trying to figure this out too.
I assume your using the 3dsmax plugin v.300?
Can you write up a very simple workflow so we can learn how to use forest pack with Octane?
Thanks in advance!
+1teffo wrote:mbetke wrote:FOrest Pack Pro works well with Octane. You have to use the FOrestTools and make all forest objects to instances and then select all the stuff and make it a movable proxy.
Thanks in advance!
Win 7 64 | 2 X MSI AERO GtX 1070| Intel I7-6850K| 32 GB DDR4 RAM | Asus X99 II-A
- jan kudelasek
- Contact:
hi. forestpack isn´t very usefull at this time, forest pack has not support for octanerender, so you have to do trick (convert all forestpack objects to instances with forest tools http://www.itoosoft.com/forestpack/reference/tools.php ). It take a lot of vram!
At this time we have support for multiscatter, i have tested it, work very well.
You can find tutorials on itoosoftware´s website for forest pack and R&D group for multiscatter.
For good 3d vegetation you have to study real nature, how it works. My advice for you
all the best Jan
all the best Jan
Do you instanciate to layer? as it is higly suggest by the software company to do it when lots of objects....jan kudelasek wrote:hi. forestpack isn´t very usefull at this time, forest pack has not support for octanerender, so you have to do trick (convert all forestpack objects to instances with forest tools http://www.itoosoft.com/forestpack/reference/tools.php ). It take a lot of vram!
all the best Jan
and any suggestion were to obtain such lovely grass as a model?
