OctaneRender® for 3ds max® v1.0 beta 3.00d[Test]
gabrielefx
nildoe wrote:Hi Karba
I think i found a bug..regarding splines, they are not renderable unless i put and edit mesh or edit poly mod on top. can Anybody confirm this please?
Nildo
confirmed and already requested
User avatar (Default)
merid888
i have a question, what image i need load in the option of normal ? a really normalmap or diffuse texture or gray scale map , becouse i can't see the relief in the scene, please, help me
thank you, i add image
slot normal
slot normal
merid888
hi, is the same problem for me, the color again, looks so different, in the slot is a color, but when i apply is more clear the tone, why happen this ?
regards
thank you karba
color different
color different
merid888
again noise in the image, maxdepth 8. maxsamples 3000, size 1229 x 887, pathtracing
why happen this ?
thank you if some one can response me
noise again
noise again
roeland
merid888 wrote:hi, is the same problem for me, the color again, looks so different, in the slot is a color, but when i apply is more clear the tone, why happen this ?
regards
thank you karba
We have done some work on improving the color accuracy of Octane. In the next release colors will look much better, especially reds and deep blues.
Roeland
Karba
merid888 wrote:again noise in the image, maxdepth 8. maxsamples 3000, size 1229 x 887, pathtracing
why happen this ?
3000 is not enough. And use pmc instead of path tracing.
gabrielefx
regards
thank you karba
Roeland
Hi Roeland and Karba
using tone mapping but saving without apply it the image is completely washed.
Is not possible to save 32 bit exr tone mapped images?
With Vray I alway save in exr or HDR format then in After effects I have full control of exposure.
Using Photoshop CS 5-6 you have full control of hdr highlights and many other parameters to balance black levels, gamma etc.
I think that Octane lacks a basic output control because all tone-film luts aren't ok for professional grading but saving a 32 bit exr file we will not able to reproduce the same Octane luts. Then it would be nice to save 32 bit toned images and then slight tweak the exposure in Photoshop or AE.
merid888
thank you for response me roeland and thak you to you too karba, i'll practice pmc and more maxsamples
regards
have a nice weekend
MaTtY631990
Hello merid888
try also to use light portals and see if it improves your render.You could possibly achieve a speed up, plus as karba mentioned use pmc in combination. And see what results you can get.
gabrielefx
***BUG***
when in pause the material editor is in pause too and picking material from mesh with the picker Octane puts random sphere previews in the slots.
Return to “Autodesk 3Ds Max”
