Blender instances "patch" for the unofficial exporter
matej
steveps3 wrote:Do you have to make the particle system real or something like that?
No. You must have the emitter object selected when you export the transforms, else it does nothing.
cgmo.net
ROUBAL
@Matej :
First test with Hair Particles : Grass tufts in a field.
The grass tuft mesh is at World origine (0,0,0). The ground mesh is at World origin as well. Rotation and scale 1/1 applied to both.
1-Exported the Grass tuft (particle object) as OBJ file.
2-Exported the Ground mesh as OBJ file.
3-Selected the Ground (particle emitter) mesh and exported the CVS file.
Rotation enabled on duplicated objects following your advice (tested also disabled).
Problem : The grass tufts are not stuck on the ground , but seem instead to be at random altitude : :roll:
matej
@Roubal, I see. My bad for doing tests only with planar emitters. I'll check this behavior in the afternoon / evening.
Actually, that setup should work (see the heart render in the first post - basically the same thing as grass). Could you post an example scene? You dont need to post the grass models, just use cones or something that has obvious directionality.
cgmo.net
Elvissuperstar007
Hello please tell me what world coords orientation octane have relatively to 3ds max?
FileName = GetSaveFileName types:"object coordinates |*.csv|"
if FileName == undefined then Exit
File = CreateFile FileName
for obj in $ do
f = obj.pos
axismatrix = obj.rotation as matrix3
rotmatrix1 = rotateXMatrix 90
rotmatrix3 = rotateZMatrix 90
--rotmatrix2 = rotateXMatrix 0
axis = (axismatrix * rotmatrix1)
--axis = (axis * rotmatrix2)
axis = (axis * rotmatrix3)
c1 = axis.row1 [1]
c2 = axis.row1 [2]
c3 = axis.row1 [3]
c5 = axis.row2 [1]
c6 = axis.row2 [2]
c7 = axis.row2 [3]
c9 = axis.row3 [1]
c10 = axis.row3 [2]
c11 = axis.row3 [3]
Format ("% % % % % % % % % % % %\n") c1 c2 c3 (f.x as float) c5 c6 c7 (f.z as float) c9 c10 c11 (-f.y as float) to:file
close file
print "File was created"
Last edited by Elvissuperstar007 on Sun Jul 29, 2012 11:02 am, edited 1 time in total.
ROUBAL
@Matej : I have just tested with Planar emitter : I encounter the same trouble ! Very weird !
Edit : I have done an other test, and this time i exported the reference grass tuft with the ground mesh : it worked fine.
I tested again on a bumpy terrain, with success. I then tried again to export the terrain mesh only, and it worked fine.
So it may be a temporary bug. I will do more trials.
matej
ROUBAL wrote:@Matej : I have just tested with Planar emitter : I encounter the same trouble ! Very weird !
I edited my previous post
cgmo.net
matej
Elvissuperstar007 wrote:Hello please tell me what world coords orientation octane have relatively to 3ds max?
Octane "up" is +Y, another usual setup is (like Blender) +Z for "up". To rotate from Blender to Octane, you need a rotational matrix of -90 around X. I duuno what orientation Max has, just look in the viewport.
Dont you Max guys have an integrated plugin, or something :D
cgmo.net
ROUBAL
@Matej : Edited my previous post as well : it works now ! I have no idea of what was going wrong ! :)
One remark, though : the size of the particles (grass tufts) is not the same in Blender and in Octane. With Dupliface, the size is the same.
matej
ROUBAL wrote: One remark, though : the size of the particles (grass tufts) is not the same in Blender and in Octane. With Dupliface, the size is the same.
Post a screenshot of your PS settings (velocity, physics, render & rotation panels open). From what I have tested scaling worked, but particles are dependent on many settings that I've missed to try and could screw things up.
(if you could post a sample scene, it would be even better)
EDIT: When you do any corrections (like scaling) to the original dupli object, you must re-export it's mesh, so that Octane works with the new mesh. I've partially written support for automatic export of dupli mesh to .obj/.mtl (works for PS, but not correctly yet for dupli emitters).
cgmo.net
ROUBAL
@Matej: everything here : blend, ocs, obj, mtl and csv.
Well, it seems to work now ! Maybe I had left a random parameter enabled by error in the geometry panel of Blender. So don't waste too much time now. I will tell you if it occurs again ! Thanks for your work ! Sorry for the trouble !
GrassParticles.zip
(604.91 KiB) Downloaded 304 times
Return to “Blender”
